[Mapserver-users] Full extent of the shape file
Kralidis,Tom [Burlington] Tom.Kralidis at ec.gc.ca
Fri Jul 23 08:35:57 EDT 2004
Try cs2cs, which comes with proj.
..Tom
-----Original Message-----
[mailto:mapserver-users-admin at lists.gis.umn.edu] On Behalf Of Thomas
Chesky
Sent: Friday, July 23, 2004 01:03
To: mapserver-users at lists.gis.umn.edu
Subject: RE: [Mapserver-users] Full extent of the shape file
Tom and Eduardo
Thanks for the reply.
ogrinfo and shpdmp gives the extent in the original coordinates of the
projection.
I am trying to get the lat/lon extent of the same.
When setting up the map file as WMS server, the GetCapabilities provides
the extent in
lan/lot as well, that is where I get the incorrect (?) boundaries of
LatLonBoundingBox minx="-111.388" miny="46.3886" maxx="-106.113"
maxy="49.1724"
What tool does mapserver uses to get the corresponding lat/lon boundary
when creating the WMS GetCapabilities XML? Is it Proj? Can it be the
problem of my PROJ installation?
Thanks
"Kralidis,Tom [Burlington]" <Tom.Kralidis at ec.gc.ca> wrote:
Try ogrinfo, i.e.
$ ogrinfo -al ./shapefile.shp
The first bit of information returned provides an overview of the data
(extent, field definitions, geometry type), then followed by a
feature-by-feature report.
..Tom
Chesky
Sent: Thursday, July 22, 2004 18:55
Subject: [Mapserver-users] Full extent of the shape file
I have the shape file, which metadata says to have the extent of
Spatial_Domain:
Bounding_Coordinates:
West_Bounding_Coordinate: -122.5
East_Bounding_Coordinate: -121.1
North_Bounding_Coordinate: 47.8
South_Bounding_Coordinate: 47.1
Mapserver however identifies the following boundary (when requested via
GetCapabilities WMS request)
king_cou
EPSG:2855
maxx="-106.113" maxy="49.1724" />
minx="1.21826e+006" miny="30932.7"
maxx="1.57787e+006" maxy="287704" />
The LatLonBoundingBox is completely different than the real boundary
defined by the meta info. Mapserver actually returns the image if
requested with an extent within "it's own" boundary but return only
blank if boundary is outside of that, but within the metainfo boundary.
Any thoughts? What tool can I use to check the full extent of a shape
file.
Why does Mapserver reads wrong full extent?
Any help would be greatly appreciated.
Thanks
Do you Yahoo!?
Vote for the stars of Yahoo!'s next ad campaign!
Do you Yahoo!?
Yahoo! Mail is new and improved - Check it out!
