[Mapserver-users] WMS Question
Jerl Simpson
jerl.simpson at rkiq.com
Fri Jul 23 11:48:41 EDT 2004
I think I have figured out this particular issue. Turns out it was not
the ":" in the layer name but the "+" I had used to replace the space.
I took the "+" out and left a " " and the error went away.
I still don't get the data I expect, but that's a separate issue I am
investigating.
Just thought I would pass that information along in case it helps
someone else.
Jerl
>>>>>>I posted a question about WMS and character URI encoding.
>>>>>>I received no response so I'm guessing no one has any suggestions.
>>>>>>I have done some searching on google and haven't found
>>anything to
>>>>>>help.
>>>>>>I would greatly appreciate it, if someone knows of any
>>documents or
>>>>>>otherwise, if they would point me in a particular direction.
>>>>>>I find it odd that the string is truncated at a ":" instead of
>>>>>>encoding it, or just passing it along as is.
>>>>>Do you have a link to the WMS you're trying to connect to?
>>>>>..Tom
>>>>>>thanks,
>>>>>>jerl
>>>>>>_______________________________________________
>>>>>>Mapserver-users mailing list Mapserver-users at lists.gis.umn.edu
>>>>>>http://lists.gis.umn.edu/mailman/listinfo/maps> erver-users
>>>>>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
