[Mapserver-users] PostgIS Layer & MapServer4
Steven Monai
stevem at spatialmapping.com
Fri Jul 23 14:29:19 EDT 2004
Jerod:
Try removing the EXPRESSION line from your CLASS. If you suddenly see a lot
of points appear, then you know the problem is in your EXPRESSION. Since
your expression is just testing for equality, you could try setting the
CLASSITEM in your LAYER to "genus" (but I see you already have) and then set
the EXPRESSION to "Aristolochia".
Another trick is to try using regular expression syntax in your EXPRESSION,
e.g.:
EXPRESSION /[Aa][Rr][Ii][Ss][Tt][Oo][Ll][Oo][Cc][Hh][Ii][Aa]/
This should match any variation of Aristolochia, including "aristolochia",
"ARISTOLOCHIA", and even "789 aRiStOLochIA123 ". If you want to exclude the
last possibility, force the regular expression to match the entire field as
follows:
EXPRESSION /^[Aa][Rr][Ii][Ss][Tt][Oo][Ll][Oo][Cc][Hh][Ii][Aa]$/
Finally, consider the possibility of leading or trailing whitespace in your
genus field. If you want to match " Aristolochia ", then try something
like the following:
EXPRESSION /^\s*[Aa][Rr][Ii][Ss][Tt][Oo][Ll][Oo][Cc][Hh][Ii][Aa]\s*$/
Good luck!
HTH,
-SM
Steven Monai
Database & Application Developer
Spatial Mapping Ltd.
484 2nd Avenue
Prince George, BC, Canada
V2L 2Z7
http://www.spatialmapping.com
mailto:stevem at spatialmapping.com
phone: 250 564 1928
fax: 250 564 0751
Jerod Clabaugh wrote:
> Date: Thu, 22 Jul 2004 15:27:35 -0500
> To: mapserver-users at lists.gis.umn.edu
> From: Jerod Clabaugh <jclabaugh at mac.com>
> Subject: [Mapserver-users] PostgIS Layer & MapServer4
> All:
> I am having trouble with PostGIS and Mapserver, specifically the
> display of point data from a table that wasn't converted from a
> shapefile.
> With my current set-up (MapServer 4.2.1, Postgres 7.4.1, PostGis 0.81
> on Mac OS X 10.3) I am able to view and query normal shape files,
> PostGIS layers (converted from shapefiles), Raster data, all just
> fine.
> I am trying to display point data from a table of species. I want to
> display all the points associated with genus records in the
> data_specimen table. The geometry column for this table is called
> 'bbox' and is a 2D Point using UTM coordinates. The specs for the
> data_specimen and geometry_column tables are listed below as well as
> sample data records. Database permissions are working fine. This
> table was not generated using shp2pgsql but was built from scratch,
> though the same data has been tested to display in standard shapefile
> input format (meaning I had it working as a shapefile first, then
> decided to build a postgres table with just the point data and try it
> as a postgis layer...)
> When I use the layer in the map file below, I get no errors, I just
> get no points showing on the map eventhough the 'Aristolochia' class
> shows up in the legend. So I am guessing its either a query problem
> in the map file or something wrong with the geometry column in the
> data_specimen table. Nothing shows up on the map, with or without the
> expression in the CLASS below. I have even tried the below
> expression with and without capital letters to no avail.
> Does anyone know what I am doing wrong here?
> Cheers,
> Jerod Clabaugh
> Belizze Biodiversity Mapping Service
> http://www.iwlearn.net/belize
> Map File layer
> LAYER
> CONNECTIONTYPE postgis
> NAME aristo1
> CONNECTION "user=jerod dbname=biodiversity host=localhost"
> DATA "bbox from data_specimen"
> TYPE POINT
> STATUS ON
> DUMP TRUE
> TEMPLATE "aristolochia.html"
> HEADER "aristolochia_header.html"
> FOOTER "aristolochia_footer.html"
> TOLERANCE 5
> CLASSITEM "genus"
> CLASS
> NAME "Aristolochia sp."
> EXPRESSION ('[genus]' eq 'Aristolochia')
> OUTLINECOLOR 75 75 75
> COLOR 39 173 33
> SYMBOL "Triangle"
> SIZE 5
> END
> END
> PostgreSQL Database Tables (data_specimen)
> TABLE data_specimen (
> specimen_id serial NOT NULL,
> scientificname character varying(50),
> kingdom integer,
> phylum integer,
> class integer,
> order character varying(40),
> family character varying(40),
> genus character varying(40),
> ../ truncated for brevity
> bbox geometry,
> CONSTRAINT "$1" CHECK ((srid(bbox) = 26716)),
> CONSTRAINT "$2" CHECK (((geometrytype(bbox) = 'POINT'::text) OR
> (bbox IS NULL)))
> ==> bbox geometry column data entered as SRID=XXXXX;POINT(XXXXX XXXXX)
> Example: SRID=26716;POINT( 1797821 298364)
> ==> There is a GIST index on 'bbox' column and oid index on entire
> 'data_specimen' table.
> Geometry Table
> TABLE geometry_columns (
> f_table_catalog character varying(256) NOT NULL,
> f_table_schema character varying(256) NOT NULL,
> f_table_name character varying(256) NOT NULL,
> f_geometry_column character varying(256) NOT NULL,
> coord_dimension integer NOT NULL,
> srid integer NOT NULL,
> "type" character varying(30) NOT NULL,
> attrelid oid,
> varattnum integer,
> stats histogram2d
> Data Record for table:
> public data_specimen bbox 2 26716 POINT
> 33744 63 \N
