[Mapserver-users] HELP {Scanned}
GONZALEZ, Jose A.
JGONZALE at ABC-USA.org
Mon Jul 26 14:20:31 EDT 2004
This is a multi-part message in MIME format.
------_=_NextPart_001_01C4733D.3C84307D
Content-Type: text/plain;
charset="us-ascii"
Content-Transfer-Encoding: quoted-printable
Zoltan,
Still no luck. The ./configure command lists yes for all PNG related
data. The only thing I don't have installed is jpeg support. Would
that have anything to do with it? Thanks for all your help I appreciate
it. - Joe
-----Original Message-----
Sent: Saturday, July 24, 2004 5:45 PM
To: GONZALEZ, Jose A.
Subject: RE: [Mapserver-users] HELP {Scanned}
You should check the output of the ./configure command.
There should be lines about PNG like:
checking where PNG is installed...
checking for png_init_io in -lpng... yes
using linpng from system libs.
If you have "no" in the second row then the pnglib installation is not
correct. Check the installation giude of mapserver.
Bye
Zoltan
On Thu, 22 Jul 2004, GONZALEZ, Jose A. wrote:
> Hello Again,
>=20
> Now the config script says its finding all the libraries including the
> new GD lib but when I run the cmd -v I still get OUTPUT=3DWBMP. I'm=20
> guessing it needs to say OUTPUT=3DPNG? Any Ideas? Is there a way to=20
> change the default OUTPUT?
>=20
> -Joe
>=20
> From: Siki Zoltan [mailto:siki at agt.bme.hu]
> Sent: Thursday, July 22, 2004 11:52 AM
>=20
>=20
> Hi,
>=20
>=20
> > Zoltan,
> >=20
> > Sorry I figure it out. I used ./mapserv -v. That seemed to do the
> > trick. This is what I get:
> >=20
> > MapServer version 4.2.1 OUTPUT=3DWBMP SUPPORTS=3DFREETYPE =
INPUT=3DEPPL7
> > INPUT=3DSHAPEFILE
> >=20
> > Does this mean I only have .bmp support? How do I get it to=20
> > configure
>=20
> > with PNG support? I did compile and install GD, zlib and libpng. =20
> > So
> > I figured that the mapserver would configure itself to these=20
> > libraries.
>=20
> Yes you have only bmp support.
> I see you use linux, then it is not enough to install the png lib, but
> the mapserver make/configure must find it. You may need change the=20
> LD_LIBRARY path that configure can find it. First run ./configure and=20
> check the output. It will propably say libpng not found. There were=20
> mails about it on the list, check the archive.
>=20
> Bye Zoltan
> >=20
> > -Joe
> >=20
> > Sent: Thursday, July 22, 2004 3:58 AM
> > Cc: mapserver-users at lists.gis.umn.edu
> > Subject: Re: [Mapserver-users] HELP {Scanned}
> >=20
> >=20
> > Hi,
> >=20
> > Check wheather PNG output is supported on your istallation. Run
> > mapserv -v command to see the supported input and output. If you
cant=20
> > see OUTPUT=3DPNG then you should install the neccessary libs for png
and
>=20
> > reconfigure/compile mapserver or change the IMAGETYPE in your map=20
> > file
>=20
> > to one of the supperted formats (GIF, JPG, ...).
> >=20
> > Bye
> > Zoltan
> >=20
> > On Wed, 21 Jul 2004, GONZALEZ, Jose A. wrote:
> >=20
> > > I need help with a new setup of mapserver. I have installed all=20
> > > the components and can't seem to run the demo file. I keep=20
> > > getting g
> the
> > > error:
> > > =20
> > > msPostMapParseOutputFormatSetup(): General error message. Unable=20
> > > to select IMAGETYPE 'PNG'.
> > > =20
> > > I've searched all the archives and can't find any solution. =20
> > > Please let me know if you have seen this error before and have a=20
> > > solution
> for
> >=20
> > > it. Thanks - Joe
> > >=20
> >=20
> >=20
>=20
>=20
Content-Type: application/ms-tnef;
name="winmail.dat"
Content-Transfer-Encoding: base64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------_=_NextPart_001_01C4733D.3C84307D--
