[Mapserver-users] null values in postgis
Vladimir Guzmán bigfoot at main-task.com
Wed Jul 28 08:36:02 EDT 2004
Kathi:
I think it must be something like:
DATA "the_geom FROM (SELECT the_geom, oid, CASE WHEN ha_dk IS NULL THEN
'' ELSE CAST (ha_dk AS VARCHAR) END AS ha_dk FROM xyz) as foo using
unique oid using srid=1"
You should run the inside query (SELECT the_geom, oid, CASE WHEN ha_dk
IS NULL THEN '' ELSE CAST (ha_dk AS VARCHAR) END AS ha_dk FROM xyz) in
the pgsql console first, and see if the query is correct.
Hope that helps,
Vladimir Ilich Guzmán R.
http://maintask.com
Kathi Koebke wrote:
> Hey Vladimir,
> sorry that I'm  so late  with my answer, but here is my sql-statement.
> The result is an empty map in mapserver.
> Maybe there' s something wrong in the sql-code or mapserver can't work
> with NULL values?  I don't know?
> DATA "the_geom FROM xyz (SELECT ha_dk CASE WHEN ha_dk IS NULL THEN ''
> ELSE CAST(ha_dk AS VARCHAR) END AS ha_dk)"
> EXPRESSION ([ha_dk] = '')
> Tschüß Kathi
> Vladimir Guzmán schrieb:
>> I've had a simmilar problem, but with oracle, and what I did was a
>> casting, for example:
>> data=the_geom FROM (SELECT CASE WHEN field IS NULL THEN ' ' ELSE
>> CAST(field AS VARCHAR) END AS field)
>> And the expression would be:
>> EXPRESSION ([field] = ' ')
>> I don't know if there is a better way to do that, but it worked.
>> Hope that helps,
