[Mapserver-users] Re: [ms4w-users] Help,How to publish vector maps
Tyler Mitchell tjmitchell at riverside.bc.ca
Wed Jul 28 12:56:30 EDT 2004
Isaac, try a really simple example first.  Then add more layers.
Also it helps to try to use shp2img on the command line with your map file
first.  That helps isolate whether it's a web server problem or a map file
problem.
I see some lines in your map file that start with "!" - what is that?
Tyler
ms4w-users-bounces at lists.maptools.org wrote on 07/27/2004 06:02:55 PM:
> Hello,
> I am trying to publish vector data but the output map did not show
> up.Below is the code for my map file.Could any of you help me out?
> MAP
>   NAME "GERMAN"
>   STATUS ON
>   EXTENT -2200000 -712631 3072800 3840000
>   SIZE 400 300
>   SHAPEPATH "./germany"
>   SYMBOLSET "./etc/symbols.sym"
>   FONTSET "./etc/fonts.txt"
>   IMAGETYPE PNG
>   IMAGECOLOR 255 255 255
>   UNITS METERS
> # Start of web interface definition
>   WEB
>     MINSCALE 2e+06
>     MAXSCALE 5e+07
> # On Windows systems, /tmp and /tmp/ms_tmp/ should be created at the
root
> # of the drive where the .MAP file resides.
>     IMAGEPATH "/ms4w/tmp/ms_tmp/"
>     IMAGEURL "/ms_tmp/"
>   END
> # Start of reference object (keymap)
> #  REFERENCE
> #    STATUS ON
> #    IMAGE "images/keymap.png"
> #    SIZE 100 75
> #    EXTENT -2.2e+06 -712631 3.0728e+06 3.84e+06
> #    COLOR -1 -1 -1
> #    OUTLINECOLOR 255 0 0
> #    MINBOXSIZE 3
> #    MAXBOXSIZE 0
> #    MARKER 0
> #    MARKERSIZE 0
> #  END
> # Start of querymap object
>   QUERYMAP
>     STATUS OFF
>     SIZE -1 -1
>     COLOR 255 0 0
>     STYLE HILITE
>   END
> # Start of legend object
>   LEGEND
>     STATUS ON
>     POSITION LL
>     KEYSIZE 18 12
>     KEYSPACING 5 5
>     TEMPLATE "ttt"
>     LABEL
>       TYPE BITMAP
>       SIZE MEDIUM
>       OFFSET 0 0
>       BUFFER 0
>       MINDISTANCE -1
>       MINFEATURESIZE -1
>       COLOR 0 0 89
>       PARTIALS TRUE
>       FORCE FALSE
>     END
>   END
> # Start of scalebar object
>   SCALEBAR
>     STATUS ON
>     COLOR 255 255 255
>     OUTLINECOLOR 0 0 0
>     BACKGROUNDCOLOR 0 0 0
>     UNITS KILOMETERS
>     INTERVALS 5
>     SIZE 150 5
>     STYLE 0
>     POSITION LL
>     LABEL
>       TYPE BITMAP
>       SIZE SMALL
>       OFFSET 0 0
>       BUFFER 0
>       MINDISTANCE -1
>       MINFEATURESIZE -1
>       COLOR 0 0 0
>       PARTIALS TRUE
>       FORCE FALSE
>     END
>   END
> # Start of OutputFormat object
>   OUT! PUTFORMAT
>     NAME "png"
>     MIMETYPE "image/png"
>     DRIVER "GD/PNG"
>     EXTENSION "png"
>     IMAGEMODE PC256
>     TRANSPARENT FALSE
>   END
> # Start of layer definitions
>   LAYER
>     NAME "deu_city"
>     STATUS ON
>     DATA "deu_city"
>     TYPE POINT
>     UNITS METERS
>     SIZEUNITS PIXELS
>     TOLERANCE 0
>     TOLERANCEUNITS PIXELS
>     METADATA
>       "DESCRIPTION"    "German Cities"
>     END
>   END # Layer
>   LAYER
>     NAME "deu_dist"
>     STATUS ON
>     DATA "deu_dist"
>     TYPE POLYGON
>     UNITS METERS
>     SIZEUNITS PIXELS
>     TOLERANCE 0
>     METADATA
>       "DESCRIPTION"    "German Districts"
>     END
>     CLASS
>     !   NAME "German Districts"
>       STYLE
>         SYMBOL 0
>         COLOR 240 240 240
>         OUTLINECOLOR 199 199 199
>         SIZE 1
>         MINSIZE 1
>         MAXSIZE 100
>       END
>     END
>   END # Layer
>   LAYER
>     NAME "deu_lake"
>     STATUS ON
>     DATA "deu_lake"
>     TYPE POLYGON
>     UNITS METERS
>     SIZEUNITS PIXELS
>     TOLERANCE 0
>     METADATA
>       "DESCRIPTION"    "German Lakes"
>     END
>   !   CLASS
>       NAME "German Lakes"
>       EXPRESSION /16|21/
>       STYLE
>         SYMBOL 0
>         COLOR 225 249 255
>         OUTLINECOLOR 186 234 245
>         SIZE 1
>         MINSIZE 1
>         MAXSIZE 100
>       END
>     END
>   END # Layer
>   LAYER
>     NAME "deu_regn"
>     STATUS ON
>     DATA "deu_regn"
>     TYPE POLYGON
>     UNITS METERS
>     SIZEUNITS PIXELS
>     TOLERANCE 0
>     METADATA
>      ! "DESCRIPTION"    "Region In Germany"
>     END
>     CLASS
>       NAME "Regions In Germany"
>       EXPRESSION "0"
>       STYLE
>         SYMBOL 0
>         COLOR 225 249 255
>         SIZE 1
>         MINSIZE 1
>         MAXSIZE 100
>       END
>     END
>   END # Layer
>   LAYER
>     NAME "deuriver"
>     STATUS ON
>     DATA "deuriver"
>     TYPE LINE
>     UNITS METERS
>     SIZEUNITS PIXELS
>     TOLERANCE 0
>   !   TOLERANCEUNITS PIXELS
>     METADATA
>       "DESCRIPTION"    "River In Germany"
>     END
>     CLASS
>       NAME "Rivers In Germany"
>       STYLE
>         SYMBOL 0
>         COLOR 120 120 120
>         SIZE 1
>         MINSIZE 1
>         MAXSIZE 100
>       END
>     END
>   END # Layer
>   LAYER
>     NAME "deuinter"
>     STATUS ON
>     DATA "deuinter"
>     TYPE LINE
>     UNITS METERS
>     SIZEUNITS PIXELS
>     TOLERANCE 0
>     TOLERANCEUNITS PIXELS    METADATA
>       "DESCRIPTION"    "Inter In Germany"
>     END
>     CLASS
>       NAME "Inter In Germany"
>       STYLE
>         SYMBOL 3
>         COLOR 0 119 255
>         SIZE 1
>         MINSIZE 1
>         MAXSIZE 100
>       END
>     END
>   END # Layer
>   LAYER
>     NAME "deustate"
>     STATUS OFF
>     DATA "deustate"
>     TYPE POLYGON
>     UNITS METERS
>     SIZEUNITS PIXELS
>     TOLERANCE 0
>     METADA! TA
>       "DESCRIPTION"    "States In Germany"
>     END
>     CLASS
>       NAME "States In Germany"
>       STYLE
>         SYMBOL 0
>         COLOR 168 0 184
>         SIZE 1
>         MINSIZE 1
>         MAXSIZE 100
>       END
>     END
>   END # Layer
> END # Map File
> Isaac Kwadwo Nti
> Kaiser Str.19,
> 76131 Karlsruhe
> Germany.
> Home Tel: +497213529267
> Mobile    : +491798846336
> The new MSN 8: smart spam protection and 2 months FREE*
> ms4w-users mailing list
> ms4w-users at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/ms4w-users
