[Mapserver-users] Fw: help on mygis
Lowell Filak
lfilak at medinaco.org
Thu Jul 29 10:09:45 EDT 2004
I don't know mygis but as a quick fix you could join all the attributes
into the first layer so there is no relate required to do the labelling.?
Lowell
The following message was sent by "pablo_schmitt_"
<pablo_schmitt_ at hotmail.com> on Thu, 29 Jul 2004 09:47:43 -0300.
> ----- Original Message -----
> From: pablo_schmitt_
> To: mapserver-users at lists.gis.umn.edu
> Sent: Wednesday, July 28, 2004 6:59 PM
> Subject: help on mygis
> hello friends
> i need some help from you
> this is a brief description of my problem:
> i have a grupos2002.shp file uploaded into mysql using the
shp2mysql.lp, > and it is working properly
> this script generated the following tables geometry_columns,
grupos2002, > grupos2002_bin, grupos2002_num
> , spatial_ref_sys
> in the map file i have this definition for the connection and data:
> CONNECTION "localhost:gisusr:gis:gisdb:bin:"
> DATA "geometry from grupos2002 feature, grupos2002_bin geometry"
> and it is working fine
> my problem is:
> i have a table zonas with the following fields:
> 1- f_Zona ( olso located in grupos2002 )
> 2- Description
> 3- Atributos
> so, i need to use the field number 2 ( Description) as Label in the
map > and i need to apply some filters using the field number
> 3 (Atributos).
> THE BIG CUESTION IS: how should i contruct my DATA definition in the
map > file ????
> i hope you could understand me
> thank you very much
> by
> pablo schmitt
> municipalidad de malvinas argentinas
> dep. informática
