[Mapserver-users] proccessing 4-Band Tiif
Aaron D. Hunt
hunt at zedxinc.com
Thu Jul 29 14:03:07 EDT 2004
Thank you for you info, I do not know much about python, but I may give
grass a try.
Aaron
Frank Warmerdam wrote:
> Aaron D. Hunt wrote:
>> Can I use mapserver to make a NDVI map from a four band tiff.
>> ie.
>> NDVI = (Band 4 - Band 3)/(Band 3 + Band 4)
>> Or does anybody know of a program that can.
> Aaron,
> There is no way to do this kind of calculation directly in MapServer.
> There are lots of programs that can do it externally such as GRASS or
> various commercial offerings. You could also write a Python script that
> uses GDAL to read and write the results and "Numeric" to do the
> computation.
> Within GDAL the gdal/pymod/samples/fft.py script shows how to use GDAL
> and
> Numeric to compute an FFT. NDVI should be somewaht simpler.
> Someday I would like to implement a kind of "virtual file" in GDAL
> where you
> can supply Python expressions for how the results should be computed from
> other source files but that is a ways out.
> Best regards,
