[Mapserver-users] Expressions with PostGIS
Vladimir Guzmán
bigfoot at main-task.com
Fri Jul 30 08:03:16 EDT 2004
Hello.
Maybe you could try:
DATA "the geom from (select the_geom, pop_cy,oid FROM tracts_c) as foo
using unique oid"
Hope that helps,
Vladimir Ilich Guzmán R.
http://maintask.com
Randy Page wrote:
> Hi All,
> Im having a heck of a time getting a basic expression to work with
> data stored in PostGIS. I have a census tract layer that I wish to
> display thematically by assigning a value range for a given variable.
> But, I cant seem to get the expression formatted correctly. Below is
> a snip from the mapfile:
> LAYER
> NAME "thematic_test"
> STATUS default
> CONNECTIONTYPE postgis
> CONNECTION "user=nifty dbname=tiger host=localhost"
> DATA "the_geom from tracts_c"
> TYPE POLYGON
> CLASSITEM "pop_cy
> CLASS
> NAME "range1"
> EXPRESSION [pop_cy] > 1000 AND [pop_cy] < 5000
> COLOR 255 0 0
> END
> Any hints would be greatly appreciated.
> Thanks,
> Randy
