[Mapserver-users] mapscript.i question
Sean Gillies sgillies at frii.com
Fri Jul 30 18:56:19 EDT 2004
On Jul 30, 2004, at 4:41 PM, Robert Thibadeau wrote:
> From the 4.2.1 release the perl mapscript readme says:
> If the mapscript_wrap.c file does not exist, copy the mapscript.i file
> into this directory and run 'swig -shadow -perl5 mapscript.i'. If you
> do
> not have swig, be sure to install the **SWIG Version 1.1 (Build 883)**
> not
> the
> 1.3.x development release.
> Swig 1.1 fails on
> %typemap(memberin,warning="451:Setting const char * member may leak
> memory.") const char * {
>   if ($input) {
>      $1 = ($1_type) malloc(strlen($input)+1);
>      strcpy((char*)$1,$input);
>   } else {
>      $1 = 0;
> and the like with a input syntax error which the second arg in the
> typemap
> (warning ...) seems to spring.
> However, using the
> SWIG Version 1.3.21
> Copyright (c) 1995-1998
> University of Utah and the Regents of the University of California
> Copyright (c) 1998-2003
> University of Chicago
> Compiled with g++ [i686-pc-linux-gnu]
> does not throw the error.
> This is kind of a catch 22: using the preferred swig throws an input
> syntax
> error
> and using the wrong compiles (at least).  What should I believe?  What
> is
> wrong
> with swig 1.3?
> regards, Bob
Bob,
The Perl stuff has fallen a bit out of date.  The README is almost
3 years old!
The wrapper code distributed with mapserver 4.2.x is generated using
swig 1.3.21.  Use that version of swig and you'll be fine.
cheers,
Sean
Sean Gillies
sgillies at frii dot com
http://users.frii.com/sgillies
