[Mapserver-users] Mapserver using MSSQL
Kalpin Kalpin
Thu Jun 3 06:59:41 EDT 2004
Dear all,
1. While I try use ogrinfo I get error like this :
     D:\openev_fw\bin>ogrinfo layer1.ovf
FAILURE:
Unable to open datasource `layer1.ovf' with the following drivers.
  -> ESRI Shapefile
  -> UK .NTF
  -> SDTS
  -> TIGER
  -> IHO S-57 (ENC)
  -> MapInfo File
  -> DGN
  -> GML
  -> AVCBin
  -> OGDI
D:\openev_fw\bin>
2. I am using Mapserver version 4.2 beta2 (ms42b2_gif_pg.zip)
3. Yes, I am using System DSN to create ODBC connection.
I have try change LAYER_1 to another one like KAMPUN_1 and still same error.
I am still need your help.
Thank you
Kalpin Erlangga Silaen
----- Original Message -----
To: "Kalpin Erlangga Silaen" <kalpin at solonet.co.id>
Cc: <mapserver-users at lists.gis.umn.edu>
Sent: Tuesday, June 01, 2004 5:27 PM
Subject: Re: [Mapserver-users] Mapserver using MSSQL
> Hi,
> 1. can ogrinfo read the ovf file successfully?
> 2. which version of Mapserver are you using (try 4.2 beta3 from
> http://www.maptools.org/php_mapscript/index.phtml?page=downloads.html).
> 3. are you using a System DSN?
> One thing which is incorrect for sure but I don't know if this is fatal,
> your <LayerSRS>LAYER_1</LayerSRS>. You can probably use your EPSG code for
> this.
> Best regards,
> Bart
> > Dear all,
> > Today, I am trying run MapServer under windows using MSSQL 2000. I have
> > read previous thread/mails and try to follow every step but I got error
> > like below :
> > msDrawMap(): Image handling error. Failed to draw layer named 'LAYER_1'.
> > msOGRFileOpen(): OGR error. Open failed for OGR connection `layer1.ovf'.
> > File not found or unsupported format.
> > My Layer code :
> > LAYER
> >   NAME LAYER_1
> >   TYPE POLYGON
> >   STATUS DEFAULT
> >   CONNECTIONTYPE OGR
> >   CONNECTION "layer1.ovf"
> >   DATA "layer1"
> >   CLASS
> >     NAME 'My City'
> >     OUTLINECOLOR 128 128 128
> >     COLOR 225 225 185
> >     TEMPLATE "layer1.html"
> >   END
> >   HEADER "layer_1_header.html"
> >   FOOTER "layer_1_footer.html"
> >   METADATA
> >     WMS_TITLE "My City"
> >     WMS_ABSTRACT "Layer Shapefile."
> >     WMS_SRS "EPSG:26915"
> >   END
> > END
> > and my layer1.ovf :
> > <OGRVRTDataSource>
> >     <OGRVRTLayer name="LAYER_1">
> >         <SrcDataSource>ODBC:sa/kalpin at mstest</SrcDataSource>
> >   <SrcLayer>River</SrcLayer>
> >  <GeometryType>wkbPoint</GeometryType>
> >  <GeometryField encoding="PointFromColumns" x="x" y="y"/>
> >     </OGRVRTLayer>
> > </OGRVRTDataSource>
> > Help me please
> > Thank you
