[Mapserver-users] Hwo to change OVERLAYSIZE from perl/php?
Sean Gillies
sgillies at frii.com
Tue Jun 1 10:21:51 EDT 2004
On Jun 1, 2004, at 7:50 AM, Hermann-Marcus Behrens wrote:
> Hello,
> I'm using the new mapserv/mapscript 4.2 and I would
> like to access OVERLAYSYMBOL and OVERLAYSIZE from within mapscript
> with perl.
> Is this not possible anymore? I tried to change the values with
> "classObj" and "styleObj", but
> both attempts failed.
> I need OVERLAYSIZE to change dynamically the "border" around polylines
> for streets.
> Before OVERLAYSYMBOL etc. were introduced, I drew the streets twofold,
> once a little bit thicker and in a darker color and the second time
> thinner with a lighter color.
> Is this a reasonable way to create borders around polylines?
> Greetings from Germany,
> Hermann Behrens
Hello Hermann,
The OVERLAYSYMBOL is deprecated. The best practice is to use multiple
styles.
In your mapfile, define two styles for a class. The second will be
rendered
over the first, the same order as layers are drawn.
To dynamically add a second (overlay) style with mapscript, do
something like
this:
$style = $class->getStyle(0); # underneath
style
$overlay_style = new mapscript::styleObj($class); # new style at
index 1
$overlay_style->{symbol} = $overlay_symbol; # a symbol
index number
$overlay_style->{size} = $overlay_size; # new symbol
size
cheers,
Sean
Sean Gillies
sgillies at frii dot com
http://users.frii.com/sgillies
