[Mapserver-users] bug postgis query alias
Merrett, Mike
mike.merrett at city.whitehorse.yk.ca
Tue Jun 1 11:55:32 EDT 2004
Try putting calls to the following function around the error lines
and printing the results i.e. echo mapserver_error();
function mapserver_error() {
$ms_err_msg ="";
$ms_error = ms_GetErrorObj();
while($ms_error && $ms_error->code != MS_NOERR)
$ms_err_msg .= "MapServer Error in :" . $ms_error->routine . "
" . $ms_error->message ."\n";
$ms_error = $ms_error->next();
return $ms_err_msg;
Hope this helps,
Mike Merrett
-----Original Message-----
[mailto:mapserver-users-admin at lists.gis.umn.edu]On Behalf Of strk
Sent: June 1, 2004 5:06 AM
To: Vladimir Guzmán
Cc: mapserver-users at lists.gis.umn.edu
Subject: Re: [Mapserver-users] bug postgis query alias
On Tue, Jun 01, 2004 at 06:56:45AM -0500, Vladimir Guzmán wrote:
> Yes, the query runs fine in the pgsql monitor:
> gps=> select gid,'>' as sentido,tiempo,360-rumbo+90 as
> rumbo,velocidad,gps_geom,oid from gps_vehi where tiempo>='2004-05-31
> 05:00:00' and tiempo<='2004-06-02 04:59:59';
> gid | sentido | tiempo | rumbo | velocidad |
> gps_geom | oid
> 46275 | > | 2004-05-31 15:16:09 | 450 | 0 |
> SRID=1;POINT(-74.06318 4.67302) | 7731018
> 46276 | > | 2004-05-31 15:16:15 | 450 | 0 |
> SRID=1;POINT(-74.06318 4.67302) | 7731019
> 46277 | > | 2004-05-31 15:16:21 | 450 | 0 |
> SRID=1;POINT(-74.06319 4.67301) | 7731020
> The error is just:
> *Warning*: MapServer Error in msDrawMap(): Failed to draw layer named
> 'puntosgps'.
> in */usr/local/apache/htdocs/gps/index.phtml* on line *33*
Ooh.. I see.. php involved!
There are lot's of auto handling of special chars with php...
Showing that line '33' would also be useful.
--strk;
> Vladimir Ilich Guzmán R.
> http://maintask.com
> strk wrote:
> >On Mon, May 31, 2004 at 03:29:45PM -0500, Vladimir Guzmán wrote:
> >>Hello.
> >>I'm implementing a gps tracking system.
> >>I want to show the car's orientation like this:
> >>http://maintask.com/test.png
> >>The layer's data is something like this:
> >>gps_geom from (select gid,sentido,tiempo,360-rumbo+90 as
> >>rumbo,velocidad,gps_geom,oid from gps_vehi where tiempo>='2004-05-29
> >>05:00:00' and tiempo<='2004-05-30 04:59:59') as foo using unique gid
> >>using srid=1
> >>The field 'sentido' contains '>'.
> >>The problem is that if I use something like this:
> >>gps_geom from (select gid,'>' as sentido,tiempo,360-rumbo+90 as
> >>using srid=1
> >>The query doesn't work.
> >>So I had to create a column in potgres called 'sentido' and all the rows
> >>containing '>'.
> >>Is this a bug?
> >What's the error message ?
> >Can you run the query from the pgsql monitor ?
> >--strk;
> >>The rest of the layer:
> >>LAYER
> >>NAME "puntosgps"
> >>CONNECTIONTYPE postgis
> >>CONNECTION "user=gps password=gps dbname=gps host=localhost"
> >>DATA "gps_geom from (select gid,sentido,tiempo,360-rumbo+90 as
> >>using srid=1"
> >>TYPE POINT
> >>PROJECTION
> >>"proj=latlong"
> >>"datum=WGS84"
> >>END
> >>LABELANGLEITEM 'rumbo'
> >>LABELITEM 'sentido'
> >>CLASS
> >> NAME 'Parado'
> >> EXPRESSION ([velocidad] = 0)
> >> SIZE 14
> >> SYMBOL 'circle'
> >> COLOR 0 0 215
> >> OUTLINECOLOR 204 204 204
> >>END
> >>CLASS
> >> NAME '0-10'
> >> EXPRESSION ([velocidad] > 0 AND[velocidad] <= 10)
> >> SIZE 14
> >> SYMBOL 'circle'
> >> COLOR 255 255 204
> >> LABEL
> >> TYPE TRUETYPE
> >> FORCE TRUE
> >> FONT arial
> >> ANTIALIAS TRUE
> >> COLOR 0 0 0
> >> OUTLINECOLOR 255 255 255
> >> SIZE 8
> >> END
> >>END
> >>Thanks a lot.
> >>http://maintask.com
> >>_______________________________________________
> >>Mapserver-users mailing list
> >>Mapserver-users at lists.gis.umn.edu
> >>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
