[Mapserver-users] Symbol - GIF pixmap - parsing problem {Scanned}
Siki Zoltan
siki at agt.bme.hu
Tue Jun 1 17:33:35 EDT 2004
Have you checked the access rights to that file?
The web server must have read access to that file.
Do you use unix or windows?
on unix use the "ls -l file-name" command to check access right,
you should see -rw-r--r-- or -rw-rw-r-- at the beginning of the line
there should be three "r"
on windows right click on the file in windows explorer and select
properties ...
Bye
Zoltan
On Tue, 1 Jun 2004, Jenu Abraham wrote:
> i'm facing a very peculiar problem
> when i was testing Symbol Pixmap ...everything worked fine with a gif file
> "north.gif" which i had downloaded from an example for mapserver...
> now i tried to develop my own image of a comapss . I converted it to
> "north.gif".
> When i tried to run this.....it gave a
> "loadsymbol().Unable to access file. Parsing error near(my image path)"
> when i again used my old image it worked
> can somebody tell me why.?
> I haVE CHECKED the image does exist at the path....
> jenu
> _________________________________________________________________
> Is your PC infected? Get a FREE online computer virus scan from McAfee®
> Security. http://clinic.mcafee.com/clinic/ibuy/campaign.asp?cid=3963
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
