[Mapserver-users] WFS client howto
Bart van den Eijnden
bartvde at xs4all.nl
Tue Jun 1 15:08:01 EDT 2004
Hi Gregor,
this is because Mapserver WFS client uses by default POST now, and the WFS
client HowTo is using HTTP GET in its examples (the docs should be updated
to include both options). So your Apache logfile only has the basic URL in
it to which a GetFeature XML request is posted.
But you have probably run into something like the following:
http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=597
Set your wfs_request_method metadata to GET then you can see in the Apache
log exactly the full request which gets sent. Or just add
request=GetFeature&BBOX=XMIN,YMIN,XMAX,YMAX to the URL you tried in a
browser (fill in the BBOX values though) and see if it works.
Best regards,
Bart
On Tue, 1 Jun 2004 11:41:03 -0700 (PDT), Gregor Mosheh
<stigmata at blackangel.net> wrote:
> Also, I noticed that in the WFS Client Howto,
> they give a connection string of:
> http://my.wfs.com/cgi-bin/mapserv?map=mywfs.map&SERVICE=WFS&VERSION=1.0.0&TYPENAME=mypoints
> But there's a mailing list entry that agrees with my experience, which
> was
> that to get any response at all you need to specify a REQUEST variable as
> well, e.g.:
> http://my.wfs.com/cgi-bin/mapserv?map=mywfs.map&SERVICE=WFS&VERSION=1.0.0&TYPENAME=mypoints&REQUEST=GetFeature
> Is this an error in the documentation, or am I missing something?
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
