[Mapserver-users] WFS client howto
Bart van den Eijnden
bartvde at xs4all.nl
Tue Jun 1 15:22:25 EDT 2004
I keep on making errors in e-mails this evening, and this one is against
the OGC spec so I have to correct myself.
The REQUEST parameter is required, but the BBOX parameter is optional. So
you do not need to add the BBOX parameter when typing the URL in a
browser, but you may use it to limit the data to be retrieved.
Best regards,
Bart
On Tue, 01 Jun 2004 21:19:38 +0200, Bart van den Eijnden
<bartvde at xs4all.nl> wrote:
> Hi Gregor,
> I read your second incoming e-mail too fast ...
> To answer your last question more precisely.
> The CONNECTION in the MAP file does not need to have a
> request=GetFeature and a BBOX as Mapserver WFS client will add that
> dynamically.
> But if you perform the request in a browser yourself, you need to add
> those parameters.
> So it is not an error in the docs.
> Best regards,
> Bart
> On Tue, 01 Jun 2004 21:08:01 +0200, Bart van den Eijnden
>> Hi Gregor,
>> this is because Mapserver WFS client uses by default POST now, and the
>> WFS client HowTo is using HTTP GET in its examples (the docs should be
>> updated to include both options). So your Apache logfile only has the
>> basic URL in it to which a GetFeature XML request is posted.
>> But you have probably run into something like the following:
>> http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=597
>> Set your wfs_request_method metadata to GET then you can see in the
>> Apache log exactly the full request which gets sent. Or just add
>> request=GetFeature&BBOX=XMIN,YMIN,XMAX,YMAX to the URL you tried in a
>> browser (fill in the BBOX values though) and see if it works.
>> Best regards,
>> Bart
>> On Tue, 1 Jun 2004 11:41:03 -0700 (PDT), Gregor Mosheh
>> <stigmata at blackangel.net> wrote:
>>> Also, I noticed that in the WFS Client Howto,
>>> they give a connection string of:
>>> http://my.wfs.com/cgi-bin/mapserv?map=mywfs.map&SERVICE=WFS&VERSION=1.0.0&TYPENAME=mypoints
>>> But there's a mailing list entry that agrees with my experience, which
>>> was
>>> that to get any response at all you need to specify a REQUEST variable
>>> as
>>> well, e.g.:
>>> http://my.wfs.com/cgi-bin/mapserv?map=mywfs.map&SERVICE=WFS&VERSION=1.0.0&TYPENAME=mypoints&REQUEST=GetFeature
>>> Is this an error in the documentation, or am I missing something?
>>> Mapserver-users mailing list
>>> Mapserver-users at lists.gis.umn.edu
>>> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
