[Mapserver-users] WFS client howto
Bart van den Eijnden bartvde at xs4all.nl
Tue Jun 1 15:30:28 EDT 2004
No it is not an error in the docs.
As I said before the request parameter is added by Mapserver WFS client
dynamically (in mapwfslayer.c). So you do not need to add it to your
CONNECTION string in the MAP file.
If you use the URL in a browser though, you need to specify it.
Hope this clears things up :)
Best regards,
Bart
On Tue, 1 Jun 2004 12:27:49 -0700 (PDT), Gregor Mosheh
<stigmata at blackangel.net> wrote:
>> The REQUEST parameter is required, but the BBOX parameter is optional.
>> So
>> you do not need to add the BBOX parameter when typing the URL in a
>> browser, but you may use it to limit the data to be retrieved.
> Got it.
> So this is an error in the docs?
> I mention it only so it could be corrected, if so.
