[Mapserver-users] WMS GetFeatureInfo reprojection problem?
Bart van den Eijnden
bartvde at xs4all.nl
Tue Jun 1 18:02:45 EDT 2004
Hi Doug,
I just tried on my data and I can reproduce the situation.
I have created a bug in bugzilla:
http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=707
Best regards,
Bart
On 01 Jun 2004 14:36:28 -0700, Doug Cates <doug at moximedia.com> wrote:
> Hi,
> I'm seeing a problem when doing a GetFeatureInfo on a MapServer 4.0.2
> WMS server instance. I'm wondering if this is a know problem....
> The problem appears when the layer is being projected on the fly (e.g
> geographic shapefile in a request in BC Albers), with the map file set
> up like this:
> NAME "usershape"
> STATUS ON
> SIZE 400 400
> UNITS METERS
> SHAPEPATH "/var/moxi_apps/web-sites/temp"
> IMAGECOLOR 255 255 255
> IMAGETYPE PNG
> SYMBOL
> NAME "square"
> TYPE vector
> FILLED true
> POINTS
> 0 0
> 0 12
> 12 12
> 12 0
> 0 0
> END
> END
> PROJECTION
> "init=epsg:42102"
> END
> WEB
> TEMPLATE "none.html"
> IMAGEPATH "/var/moxi_apps/web-sites/temp/"
> IMAGEURL "http://209.126.184.40/temp/"
> METADATA
> WMS_TITLE "User uploaded data"
> WMS_ABSTRACT "Temporary service based on user uploaded data."
> WMS_ONLINERESOURCE
> "http://www.moxi.ca/cgi-bin/mapserv?map=/var/moxi_apps/web-sites/temp/shp45091.map&"
> WMS_SRS "EPSG:42102 EPSG:4326"
> END
> END
> LAYER
> NAME "shp45091"
> TYPE POLYGON
> DATA shp45091
> STATUS ON
> PROJECTION
> "init=epsg:4326"
> END
> METADATA
> WMS_TITLE "shp45091"
> END
> DUMP TRUE
> CLASS
> COLOR 192 255 192
> OUTLINECOLOR 0 0 0
> END
> END
> END
> I'm finding that queries are not returning any results when requesting
> the GetFeatureInfo using the 42102 EPSG code:
> http://www.moxi.ca/cgi-bin/mapserv?map=/var/moxi_apps/web-sites/temp/shp45091.map&VERSION=1.1.0&REQUEST=GetFeatureInfo&LAYERS=shp45091&STYLES=&SRS=EPSG%3A42102&BBOX=13955.0,281901.0,2047779.0,1773046.0&WIDTH=832&HEIGHT=610&FORMAT=image/png&QUERY_LAYERS=shp45091&INFO_FORMAT=application/vnd.ogc.gml&FEATURE_COUNT=25&X=427&Y=263&
> The map draws fine:
> http://www.moxi.ca/cgi-bin/mapserv?map=/var/moxi_apps/web-sites/temp/shp45091.map&VERSION=1.1.0&REQUEST=GetMap&LAYERS=shp45091&STYLES=&SRS=EPSG%3A42102&BBOX=13955.0,281901.0,2047779.0,1773046.0&WIDTH=832&HEIGHT=610&FORMAT=image/png&
> Is this a bug? Should this work? Seems to me that it should....
> All the best,
> Doug
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
