[Mapserver-users] WFS client howto
Daniel Morissette
dmorissette at dmsolutions.ca
Tue Jun 1 23:45:19 EDT 2004
Gregor Mosheh wrote:
> Our WMS system works A-OK, although the rasters are often reprojected by
> the client (we use DD for the datasets, LCC or a UTM is usually used for
> the output) and so they come out looking al funky. That's what we were
> really trying to avoid. Perhaps, if WFS won't work for these needs, a
> solution could be found with WMS?
You could avoid reprojection on the client side by advertizing multiple
projections in your server's capabilities. You would do that by listing
multiple EPSG codes in the wms_srs metadata on your server, either at
the top level of the map, or in a specific layer.
e.g.
METADATA
"wms_srs" "EPSG:4326 EPSG:xxxxx EPSG:yyyy EPSG:zzzz"
END
In WMS, a layer inherits the list of SRS of its parent(s), so it's
enough to list all the supported SRS once at the top-level in the map.
Then if you use a smart WMS client it should do the right thing
automatically and request the layer in the output projection if it's
available, avoiding the raster reprojection. If you use MapServer as a
WMS client and create the mapfile by hand then you should copy the
wms_srs metadata to the client mapfile to tell MapServer which SRS are
available on the remote WMS server. Then at map display time MapServer
will try to find a matching projection in the list, and will default to
EPSG:4326 only if it can't find a match.
HTH
Daniel
Daniel Morissette dmorissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
