[Mapserver-users] EPSG codes
Daniel Morissette dmorissette at dmsolutions.ca
Wed Jun 2 00:11:47 EDT 2004
Zamil Murji wrote:
> Hello list,
> I am very new to epsg codes and I'm having some difficulty finding the correct code to use. Currently I am using a 4269 to show all of canada, however, this makes everything look so disproportionate. I am looking to use the lambert conical or lambert cylindrical codes, but I can't find them anywhere. Ideally I would like to use the same projection as the gmap application on the dmsolutions website.
There is no LCC for Canada as part of the official EPSG list, but
several sites recognize the unofficial code "EPSG:42304":
## NAD83 LCC for Canada
<42304> +proj=lcc +ellps=GRS80 +lat_0=49 +lon_0=-95 +lat_1=49 +lat_2=77
+datum=NAD83 +units=m no_defs <>
If you want to use this code with MapServer then you'll have to add the
line above to your PROJ4 "epsg" file, or download the following patched
version:
http://maptools.org/dl/proj4-epsg-with-42xxx.zip
Daniel
  DM Solutions Group              http://www.dmsolutions.ca/
