[Mapserver-users] rotating map output - any idea?
Martin Tomko
mtomko at sunrise.sli.unimelb.edu.au
Wed Jun 2 00:56:28 EDT 2004
>Hi list!
>I have a strange idea, and I would like to get some ideas about how to
>solve it..
>I would like to display a "here I am" dot, centered on the output map on a
>map (oh, not using mapscript! - so if someone knows ohw to do it, please,
>help!!). But in the same time, I would like to rotate the map by a given
>azimuth (I could send it in the cgi string as a parameter, maybe...). NOw
>- I was thinking about using False northing parameter of the projection
>for that, but I am not sure if it would not change my position on the map
>as well... For the start, lets assume that all my datasets are in the same
>projection (of course, later the "dot" will be WGS84). Any idea??
>Thanks for any input!!
>Martin
