[Mapserver-users] Problem using ODBC
Kalpin
Kalpin
Fri Jun 4 03:11:17 EDT 2004
This is a multi-part message in MIME format.
------=_NextPart_000_0076_01C44A3D.CDD5AE10
Content-Type: text/plain;
charset="iso-8859-1"
Content-Transfer-Encoding: quoted-printable
Dear all,
I have try to edit my .map like this :
LAYER
NAME blocks
TYPE POLYGON
STATUS ON
CONNECTIONTYPE OGR
CONNECTION "ODBC:sa/kalpin at MSQL"
DATA "SELECT * FROM TbBlock"
CLASS
NAME 'BLOCKS'
OUTLINECOLOR 128 128 128
COLOR 160 208 117
TEMPLATE "blocks.html"
END
HEADER "blocks_header.html"
FOOTER "blocks_footer.html"=20
METADATA
WMS_TITLE "Blocks region"
WMS_ABSTRACT "Blocks region shapefile."
WMS_SRS "EPSG:26915"
END
END
But, I get error like below :
msDrawMap(): Image handling error. Failed to draw layer named 'blocks'.=20
msOGRFileOpen(): OGR error. Open failed for OGR connection =
`ODBC:sa/kalpin at MSQL'. File not found or unsupported format.=20
What must I do ?
Thank you=20
Kalpin Erlangga Silaen
Content-Type: text/html;
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META http-equiv=3DContent-Type content=3D"text/html; =
charset=3Diso-8859-1">
<META content=3D"MSHTML 6.00.2800.1106" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY bgColor=3D#ffffff>
<DIV><FONT face=3DArial size=3D2><FONT face=3DArial size=3D2>Dear=20
all,</FONT></FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT> </DIV>
<DIV><FONT face=3DArial size=3D2>I have try to edit my .map like this =
:</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>LAYER<BR> NAME blocks<BR> =
TYPE=20
POLYGON<BR> STATUS ON<BR> CONNECTIONTYPE OGR<BR> =
CONNECTION=20
"ODBC:sa/kalpin at MSQL"<BR> DATA "SELECT * FROM TbBlock"<BR> =20
CLASS<BR> NAME 'BLOCKS'<BR> =
OUTLINECOLOR 128=20
128 128<BR> COLOR 160 208 117<BR> =
TEMPLATE=20
"blocks.html"<BR> END<BR> HEADER =
"blocks_header.html"<BR> =20
FOOTER "blocks_footer.html" <BR> METADATA<BR> =
WMS_TITLE=20
"Blocks region"<BR> WMS_ABSTRACT "Blocks region=20
shapefile."<BR> WMS_SRS "EPSG:26915"<BR> =20
END<BR>END</FONT></DIV>
<DIV><FONT face=3DArial size=3D2><FONT face=3DArial =
size=3D2></FONT></FONT> </DIV>
<DIV><FONT face=3DArial size=3D2>But, I get error like below =
:</FONT></DIV>
<DIV><FONT face=3DArial size=3D2><FONT face=3D"Times New Roman" =
size=3D3>msDrawMap():=20
Image handling error. Failed to draw layer named 'blocks'. =
<BR>msOGRFileOpen():=20
OGR error. Open failed for OGR connection `ODBC:sa/kalpin at MSQL'. File =
not found=20
or unsupported format. </FONT><BR></FONT></DIV>
<DIV><FONT face=3DArial size=3D2>What must I do ?</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Thank you </FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Kalpin Erlangga =
Silaen</DIV></FONT></BODY></HTML>
------=_NextPart_000_0076_01C44A3D.CDD5AE10--
