[Mapserver-users] Zoom In Problem
Andrew Rich
devel at itdownunder.com.au
Wed Jun 2 12:34:22 EDT 2004
This is a multi-part message in MIME format.
------=_NextPart_000_0014_01C44913.4992F2F0
Content-Type: text/plain;
charset="us-ascii"
Content-Transfer-Encoding: 7bit
Hi All
Sorry for the following bad explanation but is 2:30am here!
I have MapServ running on a Red Hat 7.3
I have copied the Itasca demo to a new folder and started to change it.
I have some Shape Files in a data dir.
I have changed the application to look at these new files.
I have configured 2 layers and they both display but the image on screen
is smaller then I would like even though the box is 600x600.
When clicking on the image it will zoom out but it will only zoom in
until the initial size. I can not zoom in any closer.
Any ideas what to be looking for?
Regards
Andrew Rich
Content-Type: text/html;
charset="us-ascii"
Content-Transfer-Encoding: quoted-printable
<html xmlns:o=3D"urn:schemas-microsoft-com:office:office" =
xmlns:w=3D"urn:schemas-microsoft-com:office:word" =
xmlns:st1=3D"urn:schemas-microsoft-com:office:smarttags" =
xmlns=3D"http://www.w3.org/TR/REC-html40">
<head>
<META HTTP-EQUIV=3D"Content-Type" CONTENT=3D"text/html; =
charset=3Dus-ascii">
<meta name=3DProgId content=3DWord.Document>
<meta name=3DGenerator content=3D"Microsoft Word 10">
<meta name=3DOriginator content=3D"Microsoft Word 10">
<link rel=3DFile-List href=3D"cid:filelist.xml at 01C44913.4755FB40">
<o:SmartTagType =
namespaceuri=3D"urn:schemas-microsoft-com:office:smarttags"
name=3D"place"/>
<o:SmartTagType =
name=3D"time"/>
<!--[if gte mso 9]><xml>
<o:OfficeDocumentSettings>
<o:DoNotRelyOnCSS/>
</o:OfficeDocumentSettings>
</xml><![endif]--><!--[if gte mso 9]><xml>
<w:WordDocument>
<w:SpellingState>Clean</w:SpellingState>
<w:GrammarState>Clean</w:GrammarState>
<w:DocumentKind>DocumentEmail</w:DocumentKind>
<w:EnvelopeVis/>
<w:Compatibility>
<w:BreakWrappedTables/>
<w:SnapToGridInCell/>
<w:WrapTextWithPunct/>
<w:UseAsianBreakRules/>
</w:Compatibility>
<w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel>
</w:WordDocument>
</xml><![endif]--><!--[if !mso]>
<style>
st1\:*{behavior:url(#default#ieooui) }
</style>
<![endif]-->
<style>
/* Style Definitions */
p.MsoNormal, li.MsoNormal, div.MsoNormal
{mso-style-parent:"";
margin:0cm;
margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:12.0pt;
font-family:"Times New Roman";
mso-fareast-font-family:"Times New Roman";}
a:link, span.MsoHyperlink
{color:blue;
text-decoration:underline;
text-underline:single;}
a:visited, span.MsoHyperlinkFollowed
{color:purple;
span.EmailStyle17
{mso-style-type:personal-compose;
mso-style-noshow:yes;
mso-ansi-font-size:10.0pt;
mso-bidi-font-size:10.0pt;
font-family:Arial;
mso-ascii-font-family:Arial;
mso-hansi-font-family:Arial;
mso-bidi-font-family:Arial;
color:windowtext;}
span.SpellE
{mso-style-name:"";
mso-spl-e:yes;}
span.GramE
{mso-style-name:"";
mso-gram-e:yes;}
@page Section1
{size:612.0pt 792.0pt;
margin:72.0pt 90.0pt 72.0pt 90.0pt;
mso-header-margin:35.4pt;
mso-footer-margin:35.4pt;
mso-paper-source:0;}
div.Section1
{page:Section1;}
</style>
<!--[if gte mso 10]>
<style>
/* Style Definitions */=20
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-padding-alt:0cm 5.4pt 0cm 5.4pt;
mso-para-margin:0cm;
mso-para-margin-bottom:.0001pt;
font-size:10.0pt;
</style>
<![endif]-->
</head>
<body lang=3DEN-US link=3Dblue vlink=3Dpurple =
style=3D'tab-interval:36.0pt'>
<div class=3DSection1>
<p class=3DMsoNormal><font size=3D2 face=3DArial><span =
style=3D'font-size:10.0pt;
font-family:Arial'>Hi All<o:p></o:p></span></font></p>
font-family:Arial'><o:p> </o:p></span></font></p>
font-family:Arial'>Sorry for the following bad explanation but is =
</span></font><st1:time
Hour=3D"2" Minute=3D"30"><font size=3D2 face=3DArial><span =
font-family:Arial'>2:30am</span></font></st1:time><font size=3D2 =
face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial'> =
here!<o:p></o:p></span></font></p>
font-family:Arial'>I have <span class=3DSpellE>MapServ</span> running on =
a Red
Hat 7.3<o:p></o:p></span></font></p>
font-family:Arial'>I have copied the </span></font><st1:place><font =
size=3D2
style=3D'font-size:10.0pt;font-family:Arial'>Itasca</span></font></st1:pl=
ace><font
style=3D'font-size:10.0pt;font-family:Arial'> demo to a
new folder and started to change it.<o:p></o:p></span></font></p>
font-family:Arial'>I have some Shape Files in a data =
dir.<o:p></o:p></span></font></p>
font-family:Arial'>I have changed the application to look at these new =
files.<o:p></o:p></span></font></p>
font-family:Arial'>I have configured 2 layers and they both display but =
the
image on screen is smaller then I would like even though the box is =
600x600.<o:p></o:p></span></font></p>
font-family:Arial'>When clicking on the image it will zoom out but it =
will only
zoom in until the initial size. <span =
style=3D'mso-spacerun:yes'> </span>I
can not zoom in any closer.<o:p></o:p></span></font></p>
font-family:Arial'>Any ideas what to be looking =
for?<o:p></o:p></span></font></p>
font-family:Arial'>Regards<o:p></o:p></span></font></p>
font-family:Arial'>Andrew Rich<o:p></o:p></span></font></p>
</div>
</body>
</html>
------=_NextPart_000_0014_01C44913.4992F2F0--
