[Mapserver-users] problems with curl
Lars Möller
moeller at basis5.de
Wed Jun 2 12:51:48 EDT 2004
hallo,
thanks for your help, but
with the spezified curl-config-path (which is correct)
I get the same error.
./configure --with-proj=/usr/local/
--with-gdal=/usr/local/bin/gdal-config
--with-ogr=/usr/local/bin/gdal-config --disable-ignore-missing-data
--with-wmsclient --with-wfsclient --with-ttf=/usr
--with-curl-config=/usr/local/bin/curl-config
Sean Gillies schrieb:
> On Jun 2, 2004, at 9:37 AM, Lars Möller wrote:
>> hi,
>> I have a problem with make.
>> I start with this configure:
>> ../configure --with-proj=/usr/local/
> Forget not to specify for curl
> --with-curl-config=PATH
> where PATH is like /usr/local/bin/curl-config
> cheers,
> Sean
> Sean Gillies
> sgillies at frii dot com
> http://users.frii.com/sgillies
_____________________________
dipl.-ing. lars möller
basis5 - webtechnologie
möller und zipp ingenieure
und partner
malsburgstrasse 14
34119 kassel
tel 0561.7660348
fax 0561.7660358
email moeller at basis5.de
www.basis5.de
