[Mapserver-users] querying WMS layer
Gregor Mosheh
stigmata at blackangel.net
Thu Jun 3 02:32:50 EDT 2004
On Wed, 2 Jun 2004, Kralidis,Tom [Burlington] wrote:
> Basically, you have to set DUMP TRUE in your LAYER object to enable
> this, as well as setting template header,body,footer.
> At this point, your WMS' GetCapabilities response will advertise your
> queryable layers with an XML attribute of 'queryable="1"', which means
> that a client can query as per the WMS spec.
I've been through both the WMS howtos a dozen times, but I just can't see
the part that describes how to set up query templates. There's a vague
reference to setting the mime type for query results, but nothing about
how setting up the templates differs from that of a "normal" mapfile. (Am
I just being dense?)
Here's a layer definition from the WMS server:
# USA state boundaries
LAYER
NAME states
TYPE polygon
STATUS on
DUMP true
CONNECTIONTYPE postgis
CONNECTION "user=XXX dbname=XXX password=XXX host=localhost"
DATA "the_geom from states"
PROJECTION
"init=epsg:4269"
END
METADATA
"wms_title" "states"
END
CLASS
OUTLINECOLOR 50 50 50
COLOR 255 255 255
TEMPLATE "states.html"
END
END
It must be partly right, cuz the GetCapabilities does indeed now say that
this is a queryable layer (previously, it did not):
<Layer queryable="1" opaque="0" cascaded="0">
<Name>states</Name>
<Title>states</Title>
(and so on)
</Layer>
So I guess the server part is working, so I need to setup the client part,
right? I put these in the client's layer definition, which worked A-OK
when the layer was in a shapefile. Now that the layer is WMS, I just get
the blank template.
TOLERANCE 4
TEMPLATE "query_templates/template_states.html"
