[Mapserver-users] mapserv.exe with max_symbols > 64
Daniel Morissette
dmorissette at dmsolutions.ca
Thu Jun 3 11:52:35 EDT 2004
Düster Horst wrote:
> I'm looking out for a mapserv.exe with a definition of max_symbols > 64 in
> ideal case with max_symbols >= 256. The mapserv.exe distributed by
> DMSolutions seems to work with the default max_symbols=64. I don't
> understand, why they don't increase from this small value to a larger value.
Simple: there is no magic number that works for everybody, and just
setting the limits to an arbitrary high value is not a solution since
that means more memory usage per request. This being said if you need a
custom build then DM Solutions can prepare one for a fee and others on
this list may be able to do it as well.
FYI there is already a bug about this, we just need time to be able to
work on it (or funding to make it a higher priority):
http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=302
Daniel
Daniel Morissette dmorissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
