[mapserver-users] querying WMS layer / WFS reprise
Paul Spencer
spencer at dmsolutions.ca
Thu Jun 3 14:52:58 EDT 2004
create btree indexes on your oid field and create GIST indexes as
suggested in the postgis documentation.
eg:
btree index (assuming oid is the object id field):
CREATE INDEX mytable_oid_idx ON mytable (oid);
GIST index (assuming wkb_geometry is your geometry column):
CREATE INDEX mytable_gist ON mytable USING GIST ( wkb_geometry
GIST_GEOMETRY_OPS );
And run VACUUM ANALYZE; after any changes to indexing to optimize the
query planner.
Cheers,
Paul
Daniel Morissette wrote:
> Gregor Mosheh wrote:
>> The queries were being done directly to the WFS server (telnet localhost
>> 80), too, not via a MapServer WFS client. It wasn't a matter of the data
>> taking a while to transfer: there was simply no activity for several
>> minutes, and then the data came across. It was definitely something
>> "inside" the WFS server, as opposed to the rendering or transit of the
>> data.
>> The result sets weren't very large: 20 or less multipolygons (zipcode
>> areas). A fair chunk of data, but it's over a LAN. The same query via WMS
>> responded in 1-2 seconds, indicating that it's the WFS stuff, as opposed
>> to the underlying data, that's taking the time.
> I think you are using PostGIS as your data layers, is that correct?
> MapServer's uses internal queries for GetFeature WFS requests, and a
> performance problem with MapServer queries on large PostGIS layers has
> been discussed on this list and on the chameleon lists in the last few
> days.
> It turned out that adding some indexes improved the query performance a
> lot. I don't know the details, hopefully others can comment or you can
> find them in the archives.
|Paul Spencer pspencer at dmsolutions.ca |
|Applications & Software Development |
|DM Solutions Group Inc http://www.dmsolutions.ca/|
