[Mapserver-users] What is CONFIG parameter for?
Thu Jun 3 18:10:45 EDT 2004
Eduardo Patto Kanegae wrote:
> I've seen in Mapserver 4.2 docs the new CONFIG parameter that was added for MAP object...
> what is the main goal of it? to avoid re-compilation of MapServer for diferrents applications?
> I saw it handles GDAL and PROJ options... what more can be done?
Eduardo,
Well, it's fairly opened ended but for now it basically passes on config
options to GDAL/OGR and the special item for the PROJ_LIB.
Best regards,
