[Mapserver-users] MapServ Compile Error after GDAL 1.2 install
Andrew Rich
devel at itdownunder.com.au
Fri Jun 4 11:28:46 EDT 2004
This is a multi-part message in MIME format.
------=_NextPart_000_001F_01C44A9C.73FC1370
Content-Type: text/plain;
charset="us-ascii"
Content-Transfer-Encoding: 7bit
Hi All
I am compiling successfully now but I cannot get projections to work.
Any ideas?
[root at tanami mapserver-4.2.0]# ./configure --with-gd=/usr/local
--with-freetype=/usr/bin --with-proj=/usr/src/proj-4.4.8
--with-gdal=/usr/local/bin/gdal-config
--with-ogr=/usr/local/bin/gdal-config --with-wmsclient --with-wfs
--with-wfsclient
[root at tanami mapserver-4.2.0]# ./mapserv -v
MapServer version 4.2.0 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
SUPPORTS=FREETYPE INPUT=TIFF INPUT=EPPL7 INPUT=JPEG INPUT=SHAPEFILE
Andrew Rich
Maps Downunder
Hi All
Initially I had MapServer working ok but I received a image from Tyler
that required a projection.
To enable projections I install GDAL 1.2.0 and PROJ 4.4.8 .
I used the following configure line
./configure --with-gd=/usr/src/gd-2.0.22 --with-proj=/usr/src/proj-4.4.8
--with-gdal=/usr/src/gdal-1.2.0/apps/gdal-config --with-wms
Then make:
[root at tanami mapserver-4.2.0]# make
gcc -O2 -Wall -DIGNORE_MISSING_DATA -DUSE_EPPL -DUSE_PROJ
-DUSE_PROJ_API_H -DUSE_WMS_SVR -DUSE_GD_PNG -DUSE_GD_JPEG
-DUSE_GD_WBMP -DUSE_GD_FT -DUSE_GDAL -I/usr/src/gd-2.0.22
-I/usr/src/proj-4.4.8/src -I/usr/src/gdal-1.2.0/port
-I/usr/src/gdal-1.2.0/gcore -I/usr/src/gdal-1.2.0/alg
-I/usr/src/gdal-1.2.0/ogr -I/usr/src/gdal-1.2.0/ogr/ogrsf_frmts
mapserv.o cgiutil.o -L. -lmap -L/usr/src/gd-2.0.22/.libs -lgd -ljpeg
-lfreetype -lpng -lz -ljpeg -lfreetype -lpng -lz
-L/usr/src/proj-4.4.8/src/.libs -lproj -ljpeg
/usr/src/gdal-1.2.0/libgdal.la -lm -o mapserv
/usr/src/gdal-1.2.0/libgdal.la: file not recognized: File format not
recognized
collect2: ld returned 1 exit status
make: *** [mapserv] Error 1
Is this GDAL-1.2 too new and should I downgrade or is it something else.
Regards
Andrew Rich
Content-Type: text/html;
charset="us-ascii"
Content-Transfer-Encoding: quoted-printable
<html xmlns:o=3D"urn:schemas-microsoft-com:office:office" =
xmlns:w=3D"urn:schemas-microsoft-com:office:word" =
xmlns:st1=3D"urn:schemas-microsoft-com:office:smarttags" =
xmlns=3D"http://www.w3.org/TR/REC-html40">
<head>
<META HTTP-EQUIV=3D"Content-Type" CONTENT=3D"text/html; =
charset=3Dus-ascii">
<meta name=3DProgId content=3DWord.Document>
<meta name=3DGenerator content=3D"Microsoft Word 10">
<meta name=3DOriginator content=3D"Microsoft Word 10">
<link rel=3DFile-List href=3D"cid:filelist.xml at 01C44A9C.71F32410">
<o:SmartTagType =
namespaceuri=3D"urn:schemas-microsoft-com:office:smarttags"
name=3D"City"/>
<o:SmartTagType =
name=3D"place"/>
<!--[if gte mso 9]><xml>
<o:OfficeDocumentSettings>
<o:DoNotRelyOnCSS/>
</o:OfficeDocumentSettings>
</xml><![endif]--><!--[if gte mso 9]><xml>
<w:WordDocument>
<w:SpellingState>Clean</w:SpellingState>
<w:GrammarState>Clean</w:GrammarState>
<w:DocumentKind>DocumentEmail</w:DocumentKind>
<w:EnvelopeVis/>
<w:Compatibility>
<w:BreakWrappedTables/>
<w:SnapToGridInCell/>
<w:WrapTextWithPunct/>
<w:UseAsianBreakRules/>
</w:Compatibility>
<w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel>
</w:WordDocument>
</xml><![endif]--><!--[if !mso]>
<style>
st1\:*{behavior:url(#default#ieooui) }
</style>
<![endif]-->
<style>
/* Style Definitions */
p.MsoNormal, li.MsoNormal, div.MsoNormal
{mso-style-parent:"";
margin:0cm;
margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:12.0pt;
font-family:"Times New Roman";
mso-fareast-font-family:"Times New Roman";}
a:link, span.MsoHyperlink
{color:blue;
text-decoration:underline;
text-underline:single;}
a:visited, span.MsoHyperlinkFollowed
{color:purple;
span.EmailStyle17
{mso-style-type:personal;
mso-style-noshow:yes;
mso-ansi-font-size:10.0pt;
mso-bidi-font-size:10.0pt;
font-family:Arial;
mso-ascii-font-family:Arial;
mso-hansi-font-family:Arial;
mso-bidi-font-family:Arial;
color:windowtext;}
span.EmailStyle18
font-family:Arial;
color:navy;}
span.EmailStyle19
{mso-style-type:personal-reply;
font-family:Arial;
color:navy;}
span.SpellE
{mso-style-name:"";
mso-spl-e:yes;}
span.GramE
{mso-style-name:"";
mso-gram-e:yes;}
@page Section1
{size:612.0pt 792.0pt;
margin:72.0pt 90.0pt 72.0pt 90.0pt;
mso-header-margin:35.4pt;
mso-footer-margin:35.4pt;
mso-paper-source:0;}
div.Section1
{page:Section1;}
</style>
<!--[if gte mso 10]>
<style>
/* Style Definitions */=20
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-padding-alt:0cm 5.4pt 0cm 5.4pt;
mso-para-margin:0cm;
mso-para-margin-bottom:.0001pt;
font-size:10.0pt;
</style>
<![endif]-->
</head>
<body lang=3DEN-US link=3Dblue vlink=3Dpurple =
style=3D'tab-interval:36.0pt'>
<div class=3DSection1>
<p class=3DMsoNormal><font size=3D2 color=3Dnavy face=3DArial><span =
style=3D'font-size:
10.0pt;font-family:Arial;color:navy'>Hi All<o:p></o:p></span></font></p>
style=3D'font-size:
10.0pt;font-family:Arial;color:navy'><o:p> </o:p></span></font></p>
style=3D'font-size:
10.0pt;font-family:Arial;color:navy'>I am compiling successfully now but =
I
cannot get projections to work.<span style=3D'mso-spacerun:yes'> =
</span><span
class=3DGramE>Any ideas?</span><o:p></o:p></span></font></p>
style=3D'font-size:
style=3D'font-size:
style=3D'font-size:
10.0pt;font-family:Arial;color:navy'>[<span =
class=3DSpellE>root at tanami</span>
mapserver-4.2.0]<span class=3DGramE># ./</span>configure --with-<span
class=3DSpellE>gd</span>=3D/<span class=3DSpellE>usr</span>/local<span
style=3D'mso-spacerun:yes'> </span>--with-<span =
class=3DSpellE>freetype</span>=3D/<span
class=3DSpellE>usr</span>/bin --with-<span =
class=3DSpellE>proj</span>=3D/usr/src/proj-4.4.8
--with-<span class=3DSpellE>gdal</span>=3D/<span =
class=3DSpellE>usr/local/bin/gdal-config</span>
--with-<span class=3DSpellE>ogr</span>=3D/<span =
--with-<span class=3DSpellE>wmsclient</span> --with-<span =
class=3DSpellE>wfs</span>
--with-<span =
class=3DSpellE>wfsclient</span><o:p></o:p></span></font></p>
style=3D'font-size:
style=3D'font-size:
mapserver-4.2.0]<span class=3DGramE># ./</span><span =
class=3DSpellE>mapserv</span>
-v<o:p></o:p></span></font></p>
<p class=3DMsoNormal><span class=3DSpellE><font size=3D2 color=3Dnavy =
face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial;color:navy'>MapServer</span><=
/font></span><font
color:navy'> version 4.2.0 OUTPUT=3DPNG OUTPUT=3DJPEG OUTPUT=3DWBMP =
SUPPORTS=3DFREETYPE
INPUT=3DTIFF INPUT=3DEPPL7 INPUT=3DJPEG =
INPUT=3DSHAPEFILE<o:p></o:p></span></font></p>
style=3D'font-size:
style=3D'font-size:
10.0pt;font-family:Arial;color:navy'>Andrew =
Rich<o:p></o:p></span></font></p>
style=3D'font-size:
10.0pt;font-family:Arial;color:navy'>Maps =
Downunder<o:p></o:p></span></font></p>
style=3D'font-size:
<div style=3D'border:none;border-left:solid blue 1.5pt;padding:0cm 0cm =
0cm 4.0pt'>
<p class=3DMsoNormal><font size=3D3 face=3D"Times New Roman"><span =
style=3D'font-size:
12.0pt'><o:p> </o:p></span></font></p>
<p class=3DMsoNormal><font size=3D2 face=3DArial><span =
font-family:Arial'>Hi All<o:p></o:p></span></font></p>
font-family:Arial'><o:p> </o:p></span></font></p>
font-family:Arial'>Initially I had MapServer working ok but I received a =
from </span></font><st1:City><st1:place><font size=3D2 =
face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial'>Tyler</span></font></st1:pla=
ce></st1:City><font
style=3D'font-size:10.0pt;font-family:Arial'> that
required a projection.<o:p></o:p></span></font></p>
font-family:Arial'>To enable projections I install GDAL 1.2.0 and PROJ =
4.4.8 .<o:p></o:p></span></font></p>
font-family:Arial'>I used the following configure =
line<o:p></o:p></span></font></p>
font-family:Arial'>./configure --with-gd=3D/usr/src/gd-2.0.22 =
--with-proj=3D/usr/src/proj-4.4.8
--with-gdal=3D/usr/src/gdal-1.2.0/apps/gdal-config =
--with-wms<o:p></o:p></span></font></p>
font-family:Arial'>Then make:<o:p></o:p></span></font></p>
font-family:Arial'>[root at tanami mapserver-4.2.0]# =
make<o:p></o:p></span></font></p>
font-family:Arial'>gcc -O2<span style=3D'mso-spacerun:yes'> =
</span>-Wall
-DIGNORE_MISSING_DATA<span style=3D'mso-spacerun:yes'> =
</span>-DUSE_EPPL
-DUSE_PROJ -DUSE_PROJ_API_H -DUSE_WMS_SVR<span
</span>-DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT<span
style=3D'mso-spacerun:yes'> </span>-DUSE_GDAL<span
</span>-I/usr/src/gd-2.0.22<span style=3D'mso-spacerun:yes'>
</span>-I/usr/src/proj-4.4.8/src<span
</span>-I/usr/src/gdal-1.2.0/port -I/usr/src/gdal-1.2.0/gcore
-I/usr/src/gdal-1.2.0/alg -I/usr/src/gdal-1.2.0/ogr
-I/usr/src/gdal-1.2.0/ogr/ogrsf_frmts<span
style=3D'mso-spacerun:yes'> </span><span
style=3D'mso-spacerun:yes'> </span>mapserv.o cgiutil.o<span
style=3D'mso-spacerun:yes'> </span>-L. -lmap
-L/usr/src/gd-2.0.22/.libs -lgd -ljpeg -lfreetype -lpng -lz<span
style=3D'mso-spacerun:yes'> </span>-ljpeg -lfreetype =
-lpng
-lz<span style=3D'mso-spacerun:yes'>
</span>-L/usr/src/proj-4.4.8/src/.libs -lproj -ljpeg<span
</span>/usr/src/gdal-1.2.0/libgdal.la<span
</span>-lm<span style=3D'mso-spacerun:yes'> </span>-o =
mapserv<o:p></o:p></span></font></p>
font-family:Arial'>/usr/src/gdal-1.2.0/libgdal.la: file not recognized: =
File
format not recognized<o:p></o:p></span></font></p>
font-family:Arial'>collect2: ld returned 1 exit =
status<o:p></o:p></span></font></p>
font-family:Arial'>make: *** [mapserv] Error =
1<o:p></o:p></span></font></p>
font-family:Arial'>Is this GDAL-1.2 too new and should I downgrade or is =
it
something else.<o:p></o:p></span></font></p>
font-family:Arial'>Regards<o:p></o:p></span></font></p>
font-family:Arial'>Andrew Rich<o:p></o:p></span></font></p>
</div>
</div>
</body>
</html>
------=_NextPart_000_001F_01C44A9C.73FC1370--
