[Mapserver-users] functions to parse a map file?
Mark Adams
markadams at cuestasys.com
Fri Jun 4 16:39:25 EDT 2004
This is a multi-part message in MIME format.
------=_NextPart_000_000F_01C44A52.7FB0BF80
Content-Type: text/plain;
charset="iso-8859-1"
Content-Transfer-Encoding: quoted-printable
Hi all,
=20
We are developing a sample site with Mapserver 4.2 and PHP mapscript.
We=92d like to add some custom functions that require that we can
determine at run time certain aspects of the layers being published
through the map file, for example what type of data the layer is (e.g.
raster, shapefile), what its geometry type is (e.g. polygon, line), etc.
We had been thinking we=92d parse the map file on initial load, and =
access
it programmatically from a set of arrays; but as the map file structure
is not XML based there isn=92t an easy way of parsing the map file
directly. Are there any built-in functions available to allow us to do
this?
=20
Thanks for any help you can provide.
=20
Mark Adams
Business & Systems Analyst
Cuesta Systems Inc.
5230 South Service Road
Burlington, ON L7L 5K2
Phone: 905-333-4544 x14
Fax: 905-333-0455
Email: markadams at cuestasys.com
=20
Content-Type: text/html;
<html xmlns:o=3D"urn:schemas-microsoft-com:office:office" =
xmlns:w=3D"urn:schemas-microsoft-com:office:word" =
xmlns:st1=3D"urn:schemas-microsoft-com:office:smarttags" =
xmlns=3D"http://www.w3.org/TR/REC-html40">
<head>
<META HTTP-EQUIV=3D"Content-Type" CONTENT=3D"text/html; =
charset=3Diso-8859-1">
<meta name=3DProgId content=3DWord.Document>
<meta name=3DGenerator content=3D"Microsoft Word 10">
<meta name=3DOriginator content=3D"Microsoft Word 10">
<link rel=3DFile-List href=3D"cid:filelist.xml at 01C44A52.7F66BE30">
<o:SmartTagType =
namespaceuri=3D"urn:schemas-microsoft-com:office:smarttags"
name=3D"PersonName"/>
<!--[if gte mso 9]><xml>
<o:OfficeDocumentSettings>
<o:DoNotRelyOnCSS/>
</o:OfficeDocumentSettings>
</xml><![endif]--><!--[if gte mso 9]><xml>
<w:WordDocument>
<w:SpellingState>Clean</w:SpellingState>
<w:GrammarState>Clean</w:GrammarState>
<w:DocumentKind>DocumentEmail</w:DocumentKind>
<w:EnvelopeVis/>
<w:Compatibility>
<w:BreakWrappedTables/>
<w:SnapToGridInCell/>
<w:WrapTextWithPunct/>
<w:UseAsianBreakRules/>
</w:Compatibility>
<w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel>
</w:WordDocument>
</xml><![endif]--><!--[if !mso]>
<style>
st1\:*{behavior:url(#default#ieooui) }
</style>
<![endif]-->
<style>
/* Style Definitions */
p.MsoNormal, li.MsoNormal, div.MsoNormal
{mso-style-parent:"";
margin:0in;
margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:12.0pt;
font-family:"Times New Roman";
mso-fareast-font-family:"Times New Roman";}
a:link, span.MsoHyperlink
{color:blue;
text-decoration:underline;
text-underline:single;}
a:visited, span.MsoHyperlinkFollowed
{color:purple;
p.MsoAutoSig, li.MsoAutoSig, div.MsoAutoSig
{margin:0in;
font-size:12.0pt;
span.EmailStyle17
{mso-style-type:personal-compose;
mso-style-noshow:yes;
mso-ansi-font-size:10.0pt;
mso-bidi-font-size:10.0pt;
font-family:Arial;
mso-ascii-font-family:Arial;
mso-hansi-font-family:Arial;
mso-bidi-font-family:Arial;
color:windowtext;}
span.SpellE
{mso-style-name:"";
mso-spl-e:yes;}
@page Section1
{size:8.5in 11.0in;
margin:1.0in 1.25in 1.0in 1.25in;
mso-header-margin:.5in;
mso-footer-margin:.5in;
mso-paper-source:0;}
div.Section1
{page:Section1;}
</style>
<!--[if gte mso 10]>
<style>
/* Style Definitions */=20
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
font-size:10.0pt;
</style>
<![endif]-->
</head>
<body lang=3DEN-US link=3Dblue vlink=3Dpurple =
style=3D'tab-interval:.5in'>
<div class=3DSection1>
<p class=3DMsoNormal><font size=3D2 face=3DArial><span =
style=3D'font-size:10.0pt;
font-family:Arial'>Hi all,<o:p></o:p></span></font></p>
font-family:Arial'><o:p> </o:p></span></font></p>
font-family:Arial'>We are developing a sample site with <span =
class=3DSpellE>Mapserver</span>
4.2 and PHP <span class=3DSpellE>mapscript</span>. We’d like to =
add some
custom functions that require that we can determine at run time certain =
aspects
of the layers being published through the map file, for example what =
type of
data the layer is (e.g. raster, <span class=3DSpellE>shapefile</span>), =
what its
geometry type is (e.g. polygon, line), etc. We had been thinking =
we’d
parse the map file on initial load, and access it programmatically from =
a set
of arrays; but as the map file structure is not XML based there =
isn’t an
easy way of parsing the map file directly. Are there any built-in =
functions
available to allow us to do this?<o:p></o:p></span></font></p>
font-family:Arial'>Thanks for any help you can =
provide.<o:p></o:p></span></font></p>
<p class=3DMsoAutoSig><font size=3D3 color=3Dnavy face=3D"Times New =
Roman"><span
style=3D'font-size:12.0pt;color:navy;mso-no-proof:yes'>------------------=
------------</span></font><span
style=3D'mso-no-proof:yes'><o:p></o:p></span></p>
<p class=3DMsoAutoSig><st1:PersonName><font size=3D3 color=3Dnavy
face=3D"Times New Roman"><span =
yes'>Mark Adams</span></font></st1:PersonName><span =
Roman"><span
style=3D'font-size:12.0pt;color:navy;mso-no-proof:yes'>Business & =
Systems
Analyst</span></font><span =
Roman"><span
style=3D'font-size:12.0pt;color:navy;mso-no-proof:yes'>Cuesta Systems =
Inc.</span></font><span
Roman"><span
style=3D'font-size:12.0pt;color:navy;mso-no-proof:yes'>5230 South =
Service Road</span></font><span
Roman"><span
style=3D'font-size:12.0pt;color:navy;mso-no-proof:yes'>Burlington, ON =
L7L 5K2</span></font><span
Roman"><span
style=3D'font-size:12.0pt;color:navy;mso-no-proof:yes'>Phone: =
905-333-4544 x14</span></font><span
Roman"><span
style=3D'font-size:12.0pt;color:navy;mso-no-proof:yes'>Fax: =
905-333-0455</span></font><span
Roman"><span
style=3D'font-size:12.0pt;color:navy;mso-no-proof:yes'>Email:
markadams at cuestasys.com</span></font><span =
<p class=3DMsoNormal><font size=3D3 face=3D"Times New Roman"><span =
style=3D'font-size:
12.0pt'><o:p> </o:p></span></font></p>
</div>
</body>
</html>
------=_NextPart_000_000F_01C44A52.7FB0BF80--
