[Mapserver-users] Mapserver GML valid?
Kralidis,Tom [Burlington]
Tom.Kralidis at ec.gc.ca
Fri Jun 4 17:36:26 EDT 2004
That's wierd, too. I tried a GetFeature XML output against xsv
(http://www.w3.org/2001/03/webdata/xsv), but I get other errors:
Schema representation errors
Detected during instance validation
http://schemas.opengis.net/gml/2.1.2/xlinks.xsd:19:3: Invalid:
restricting attribute with type {http://www.w3.org/1999/xlink}None not
derived from declared base's attribute's type
http://www.w3.org/1999/xlink{None}
http://schemas.opengis.net/gml/2.1.2/xlinks.xsd:46:3: Invalid:
...but it doesn't complain about the schemaLocation defined.
We might want to check this with the WFS mailing list.
..Tom
> -----Original Message-----
> From: mapserver-users-admin at lists.gis.umn.edu
> [mailto:mapserver-users-admin at lists.gis.umn.edu] On Behalf Of
> Yewondwossen Assefa
> Sent: Friday, June 04, 2004 10:14 AM
> To: bartvde at xs4all.nl
> Cc: mapserver-users at lists.gis.umn.edu
> Subject: Re: [Mapserver-users] Mapserver GML valid?
> Bart,
> I have made the changes to point vers the 2.1.2.
> There is though still a problem validating these using XML SPY. We
> have run into this problem previously but did not come up with an
> explanation : usally I do the validations using the following
> OGC site
> http://cite.occamlab.com/gmlTools/validateInstance.jsp. When running
> the same "valid" XML through XML SPY, we get the error you
> got. The problem seems to be that XMP Spy seems to not read
> or cannot get the
> DescribeFeatureType schema. If you save that schema into a local file
> and modify your XML to point to this local file, It validates through
> XML Spy. I still do not have a reasonable explanation for
> this (but I
> really do not know much either about XML Spy and what and what not is
> possible).
> Later,
> > Hi list,
> > I was just checking Mapserver GML in XML Spy and I get and
> error. I am
> > using Mapserver 4.2.
> > The error I get is:
> > Mandatory element 'gml:_Feature' expected in place of Gemeentes.
> > In the DescribeFeatureType response there is another problem (but
> > maybe
> > this is the cause of the first problem as well?):
> > the URL to the GML schema is:
> > http://ogc.dmsolutions.ca/gml/2.1.1/feature.xsd
> > This one does not exist anymore, the 2.1.2 feature schema does exist
> > though. The version number is hardcoded in mapwfs.c.
> > Anybody else experiencing these (validation) errors?
> > Best regards,
> > Bart
> > annex 1: part of my GetFeature response
> > <gml:featureMember>
> > <Gemeentes>
> > <gml:boundedBy>
> > <gml:Box srsName="EPSG:28992">
> > <gml:coordinates>
> > 128558.900000,499724.500000
> 134533.400000,504609.100000
> > </gml:coordinates>
> > </gml:Box>
> > </gml:boundedBy>
> > <gml:polygonProperty>
> > <gml:Polygon srsName="EPSG:28992">
> > <gml:outerBoundaryIs>
> > <gml:LinearRing>
> > <gml:coordinates>
> > 130401.300000,503894.099900
> > 130579.500000,503799.700000 131548.000100,503660.100000
> > 131489.700000,503858.000100 131773.100000,503932.700000
> > 131865.299900,503957.200000 133099.299900,504609.100000
> > 133209.000000,503977.500000 133441.100100,503733.100000
> > 133588.099900,503473.100000 133861.299900,503540.300000
> > 133861.299900,503540.300000 133739.700100,503372.699900
> > 133760.600000,503139.200000 134174.500100,502917.000100
> > 134230.899900,502735.900100 134384.800100,502258.900000
> > 134533.400000,501841.800000 134216.599900,501423.499900
> > 133983.900100,500917.300000 134003.299900,500788.400000
> > 133575.500000,500471.900100 133399.400000,500240.300100
> > 133139.800100,500297.000000 133139.800100,500297.000000
> > 133069.900000,500287.900000 133057.400100,500369.900000
> > 133057.400100,500369.900000 132947.700000,500323.300100
> > 132906.199900,500143.199900 132795.700100,500081.500100
> > 132776.900000,499981.900100 132728.600000,499724.500000
> > 132585.400100,499766.800100 132679.000100,500372.900100
> > 132679.000100,500372.900100 131675.199900,500164.400000
> > 130918.799900,500093.699900 130714.099900,499988.699900
> > 130378.899900,499801.400100 130024.900000,499980.300100
> > 128558.900000,500826.300000 129112.200100,501755.900100
> > 130401.300000,503894.099900 </gml:coordinates>
> > </gml:LinearRing>
> > </gml:outerBoundaryIs>
> > </gml:Polygon>
> > </gml:polygonProperty>
> > <GEMCODE>0385</GEMCODE>
> > <GEMNR>385</GEMNR>
> > <GEMNAAM>Edam-Volendam</GEMNAAM>
> > <INWONERS>26852</INWONERS>
> > <GROEI>12</GROEI>
> > <GROEI_>0.04</GROEI_>
> > <PROVCODE>27</PROVCODE>
> > <PROVNR>27</PROVNR>
> > <PROVNAAM>Noord-Holland</PROVNAAM>
> > <COROPCODE>23</COROPCODE>
> > <COROPNAAM>Groot-Amsterdam</COROPNAAM>
> > <NODAAL>44</NODAAL>
> > <NODAALNAAM>Amsterdam</NODAALNAAM>
> > <CEBUCO>21</CEBUCO>
> > <CEBUCOSUB>21.2</CEBUCOSUB>
> > <CEBUCONAAM>Amsterdam-Purmerend</CEBUCONAAM>
> > <NIELSEN>West</NIELSEN>
> > <NIELCOD>2</NIELCOD>
> > <EGG>057</EGG>
> > <EGGNAAM>Waterland</EGGNAAM>
> > <RBA>10</RBA>
> > <RBANAAM>Zuidelijk Noord-Holland</RBANAAM>
> > <WM61>34</WM61>
> > <WM61NAAM>ROA</WM61NAAM>
> > <WM55>34</WM55>
> > <WM55NAAM>ROA</WM55NAAM>
> > <KVKCODE>9</KVKCODE>
> > <KVKNAAM>Hoorn</KVKNAAM>
> > <POLITIE>11</POLITIE>
> > <POLITIENM>Zaanstreek-Waterland</POLITIENM>
> > <NLGE_R98_I>136</NLGE_R98_I>
> > </Gemeentes>
> > </gml:featureMember>
> > annex 2: part of my DescribeFeatureType response
> > <schema
> > targetNamespace="http://www.ttt.org/myns"
> > xmlns:myns="http://www.ttt.org/myns"
> > xmlns:ogc="http://www.opengis.net/ogc"
> > xmlns:xsd="http://www.w3.org/2001/XMLSchema"
> > xmlns="http://www.w3.org/2001/XMLSchema"
> > xmlns:gml="http://www.opengis.net/gml"
> > elementFormDefault="qualified" version="0.1" >
> > <import namespace="http://www.opengis.net/gml"
> > schemaLocation="http://ogc.dmsolutions.ca/gml/2.1.1/feature.xsd" />
> > <element name="Gemeentes"
> > type="myns:Gemeentes_Type"
> > substitutionGroup="gml:_Feature" />
> > <complexType name="Gemeentes_Type">
> > <complexContent>
> > <extension base="gml:AbstractFeatureType">
> > <sequence>
> > <element ref="gml:polygonProperty" minOccurs="0" />
> > <element name="GEMCODE" type="string" />
> > Mapserver-users mailing list Mapserver-users at lists.gis.umn.edu
> > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
> Assefa Yewondwossen
> Software Analyst
> Email: assefa at dmsolutions.ca
> http://www.dmsolutions.ca/
> Phone: (613) 565-5056 (ext 14)
> Fax: (613) 565-0925
