[Mapserver-users] .shp file to .map file
Norbert Thieme
norbert.thieme at ilmenau.baw.de
Mon Jun 7 07:04:01 EDT 2004
Alexander Lim schrieb:
> hi guys,
> sorry for this totally newbie question.
> i just got everything setup including php/mapscript.
> and i m starting to read the how-to by example. my
> question is on map file that mapserver uses. does this
> map file follows a "universal" standard just like .shp
> file or is it solely a mapserver format. the reason i
> m asking this is that i have .shp files of a country
> which were converted from mapinfo map and tab file
> format. is there a converter to convert .shp to
> mapserver map file or can i even use .shp file
> directly.
> thanks for any advice.
> alex
> __________________________________
> Do you Yahoo!?
> Friends. Fun. Try the all-new Yahoo! Messenger.
> http://messenger.yahoo.com/
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Hi.
.shp and .map files are not the same. .shp/.shx/.dbf are data files and
a .map file is - let's say something like a config file for the data
written in normal and readable text. There's is nothing to convert but
have a look at:
http://mapserver.gis.umn.edu/contributed.html
there are sure some tools to easily generate a map file.
You can also write it yourself in a normal text file with an simple
editor and change .txt to .map. Look at:
http://mapserver.gis.umn.edu/doc40/mapfile-reference.html
If you have a mapfile then there are layers where you can specify your
data like .shp files. So you can use the .shp directly.
Regards,
Norbert
