[Mapserver-users] Virtual Spatial Data from SQL Server
Jenu Abraham
jenu_ab at hotmail.com
Mon Jun 7 10:58:35 EDT 2004
hi charli...
can u check one thing...
when u run the command "ogrinfo urfile.ovf" does it show the table u want to
access at the end of the lines, or some other table from the same database
where ur ODBC is pointing..
and i'm sorry i lost track whre u were getting the err..so can u again tell
me exactly what ur problem was...
jenu
>From: "IMD Listuser" <imd_listuser at comcast.net>
>To: "Jenu Abraham" <jenu_ab at hotmail.com>,"IMD Listuser"
>CC: <Mapserver-users at lists.gis.umn.edu>
>Subject: RE: [SPAM] - Re: [Mapserver-users] Virtual Spatial Data from SQL
>Server - Email found in subject
>Date: Mon, 7 Jun 2004 07:33:19 -0400
>Thanks Jenu,
>Unfortunately your suggestions did not seem to make a difference.
>I am thinking that the problem is with permissions on IIS6, since it its
>locked down by default. Im not sure that it will allow ODBC connections
>to occur unless I explicitly allow them. So, I need to figure out how to
>allow them.
>Thanks Again
>Charlie
>-----Original Message-----
>From: Jenu Abraham [mailto:jenu_ab at hotmail.com]
>Sent: Saturday, June 05, 2004 11:05 AM
>To: IMD Listuser
>Cc: Mapserver-users at lists.gis.umn.edu
>Subject: [SPAM] - Re: [Mapserver-users] Virtual Spatial Data from SQL
>Hi charlie
>did u say that u are getting any error or u just dont see the points on
>the map,
>if u see the map but not a point then try adding a dummy symbol layer in
>the mapfile....i was facing the same problem...this helped...
>also make sure u have the sign in the map right
>for the western hemispehere the longitues are negative and northern
>hemisphere the latitudes are positive
>write back if u still facing the problem
>cheers
>jenu
>_________________________________________________________________
>Getting married? Find great tips, tools and the latest trends at MSN
>Life Events. http://lifeevents.msn.com/category.aspx?cid=married
MSN 9 Dial-up Internet Access fights spam and pop-ups now 3 months FREE!
http://join.msn.click-url.com/go/onm00200361ave/direct/01/
