[Mapserver-users] SLD Support and MapServer 4.2
Steve MacLean maclean at linnet.ca
Mon Jun 7 15:33:32 EDT 2004
I have USE_OGR enabled and SLD doesn't work.  This is what is in the make
file for OGR
GR=-DUSE_OGR
GDAL_DIR=c:\development\mapserver\compile\build\gdal-1.2.0
Thanks
Steve
-----Original Message-----
From: Yewondwossen Assefa [mailto:assefa at dmsolutions.ca]
Sent: Monday, June 07, 2004 2:07 PM
To: Steve MacLean
Cc: 'mapserver-users at lists.gis.umn.edu'
Subject: Re: [Mapserver-users] SLD Support and MapServer 4.2
You should build with USE_OGR (wich is used to parse the xml files).
Later,
Steve MacLean wrote:
> Hi,
> We are using MapServer 4.2 on Windows 2000 compiled with Micosoft Visual
> C++.  We would like to use MapServer as a WMS server and have SLD support
> enabled.  Doe anything special have to be done during the compile of
> Mapserver to to enable SLD support besides enabling it as a WMS Client and
> WMS Server?  The reason I ask is that we can't get SLD to work with our
> builds of MapServer.  If we use the Win32 binaries for MapServer 4.2b
> downloaded from the MapServer web site SLD works.  Unfortunatly we can't
use
> the binaries on the web site because the Virtual Spatial Server option
> doesn't seem to be enabled on it.
> I can supply the makefiles that i used when building MapServer and the
> required libraries.
> Any help would be appreciated.
> Thanks
> Steve
> Steve MacLean
> 204-957-6248
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax:   (613) 565-0925
