[Mapserver-users] Mapserver doesn't create image, no crash
Berend Veldkamp
berend.veldkamp at aris.nl
Wed Jun 9 11:50:34 EDT 2004
I'm in the process of upgrading an old mapserver CGI (3.4) application
to 4.2. I have most things working now, but it seems that now and then
mapserver doesn't create a map image (there's nothing in the tmp dir).
Instead, I get the following output:
<HTML>
<HEAD><TITLE>MapServer Message</TITLE></HEAD>
<!-- MapServer version 4.2.0 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
OUTPUT=PDF SUPPORTS=FREETYPE INPUT=EPPL7 INPUT=GDAL INPUT=SHAPEFILE -->
<BODY BGCOLOR="#FFFFFF">
</BODY></HTML>
It seems it depends on which layers I have turned on, and which area I'm
zoomed in to. However I can't find a clear pattern, sometimes I have to
turn on a particular layer to make it work, other times I have to turn
off a layer.
When I turn on logging in the WEB object, I get this:
Wed Jun 9 17:37:32 2004,21917,127.0.0.1,vl,0,172329.357920
438926.688000 196177.642080 453219.312000,0.000000 0.000000,route bkgrnd
nummers roads landuse ,normal execution
Wed Jun 9 17:37:42 2004,21928,127.0.0.1,vl,0,172329.357920
nummers roads toerinfo landuse ,
On the second line, 'toerinfo' is turned on, and I don't get the 'normal
execution' message.
I have no idea where to start looking, so any hints are appreciated.
I already tried (to no avail):
- Different ouput format (jpeg, png, png 24 bit)
- Upgrading GD to 2.0.26
- Removing all antialiasing, backgroundcolors, pixmap symbols etc,
reducing the number of colors from >1000 to 15
- Tried MS 4.0 and 4.2
Thanks in advance, Berend
