[Mapserver-users] Projection and/or Extent problem
Eric Fegraus
fegraus at nceas.ucsb.edu
Wed Jun 9 16:11:47 EDT 2004
This is a multi-part message in MIME format.
------=_NextPart_000_0006_01C44E23.51E72060
Content-Type: text/plain;
charset="us-ascii"
Content-Transfer-Encoding: quoted-printable
Hello,
I'm beginning with Mapserver. Have it installed on Linux with Apache. =
I'm
trying to make an image of one of my shapefiles. The image is created =
but
the size of the shapefile as part of the image is about 1/100 the size =
of
the image (i.e. most all the image is white and the shapefile appears in =
the
top left corner of the image). Have a feeling it must be due to my =
extent
and/or Projection. Any ideas?
Thanks!
Eric
Start of map file
MAP
IMAGETYPE PNG
NAME Test
STATUS ON
SIZE 400 400
EXTENT 283091.000000 352956.000000 7529638.000000 7427241.000000
UNITS METERS
SHAPEPATH "data"
IMAGECOLOR 255 255 255
# Projection definition, consult the PROJ.4 documentation for =
parameter
discussion
PROJECTION
"proj=3Dutm"
"zone=3D36"
"south"
"ellps=3DWGS84"
"datum=3DWGS84"
"units=3Dm"
"no_defs"
# OR:
# "init=3Depsg:32736"
END
#-- Begin layer defs.---------------------
LAYER
PROJECTION
"proj=3Dutm"
"datum=3DWGS84"
END
NAME SOILS_shape =20
TYPE POLYGON
STATUS DEFAULT
DATA SOILS_shape
CLASS
OUTLINECOLOR 128 128 128
COLOR 225 225 185
END #-- End class def.
END #--End Layer def.
END #-- End Map File
Content-Type: text/html;
charset="us-ascii"
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 3.2//EN">
<HTML>
<HEAD>
<META HTTP-EQUIV=3D"Content-Type" CONTENT=3D"text/html; =
charset=3Dus-ascii">
<META NAME=3D"Generator" CONTENT=3D"MS Exchange Server version =
6.0.4630.0">
<TITLE>Projection and/or Extent problem</TITLE>
</HEAD>
<BODY>
<!-- Converted from text/rtf format -->
<P><FONT SIZE=3D2 FACE=3D"Arial">Hello,</FONT>
</P>
<P><FONT SIZE=3D2 FACE=3D"Arial">I'm beginning with Mapserver. =
Have it installed on Linux with Apache. I'm trying to make an =
image of one of my shapefiles. The image is created but the size =
of the shapefile as part of the image is about 1/100 the size of the =
image (i.e. most all the image is white and the shapefile appears in the =
extent and/or Projection. Any ideas?</FONT></P>
<P><FONT SIZE=3D2 FACE=3D"Arial">Thanks!</FONT>
<BR><FONT SIZE=3D2 FACE=3D"Arial">Eric</FONT>
<BR><FONT SIZE=3D2 =
FACE=3D"Arial">----------------------------------------------------------=
-----------------------------------------------------</FONT>
<BR><FONT SIZE=3D2 FACE=3D"Arial"> Start of map file</FONT>
<BR><FONT SIZE=3D2 FACE=3D"Arial">#</FONT>
<BR><FONT SIZE=3D2 FACE=3D"Arial">MAP</FONT>
<BR><FONT SIZE=3D2 FACE=3D"Arial"> IMAGETYPE PNG</FONT>
<BR><FONT SIZE=3D2 FACE=3D"Arial"> NAME Test</FONT>
<BR><FONT SIZE=3D2 FACE=3D"Arial"> STATUS ON</FONT>
<BR><FONT SIZE=3D2 FACE=3D"Arial"> SIZE 400 400</FONT>
<BR><FONT SIZE=3D2 FACE=3D"Arial"> EXTENT 283091.000000 =
352956.000000 7529638.000000 7427241.000000</FONT>
<BR><FONT SIZE=3D2 FACE=3D"Arial"> UNITS METERS</FONT>
<BR><FONT SIZE=3D2 FACE=3D"Arial"> SHAPEPATH =
"data"</FONT>
<BR><FONT SIZE=3D2 FACE=3D"Arial"> IMAGECOLOR 255 255 255</FONT>
<BR><FONT SIZE=3D2 FACE=3D"Arial"> #</FONT>
<BR><FONT SIZE=3D2 FACE=3D"Arial"> # Projection definition, =
consult the PROJ.4 documentation for parameter discussion</FONT>
<BR><FONT SIZE=3D2 FACE=3D"Arial"> PROJECTION</FONT>
<BR><FONT SIZE=3D2 FACE=3D"Arial"> =
"proj=3Dutm"</FONT>
"zone=3D36"</FONT>
"south"</FONT>
"ellps=3DWGS84"</FONT>
"datum=3DWGS84"</FONT>
"units=3Dm"</FONT>
"no_defs"</FONT>
<BR><FONT SIZE=3D2 FACE=3D"Arial"> # OR:</FONT>
<BR><FONT SIZE=3D2 FACE=3D"Arial"># =
"init=3Depsg:32736"</FONT>
<BR><FONT SIZE=3D2 FACE=3D"Arial"> END</FONT>
<BR><FONT SIZE=3D2 FACE=3D"Arial">#-- Begin layer =
defs.---------------------</FONT>
</P>
<P><FONT SIZE=3D2 FACE=3D"Arial"> LAYER</FONT>
"proj=3Dutm"</FONT>
<BR><FONT SIZE=3D2 FACE=3D"Arial"> NAME =
SOILS_shape </FONT>
<BR><FONT SIZE=3D2 FACE=3D"Arial"> TYPE POLYGON</FONT>
<BR><FONT SIZE=3D2 FACE=3D"Arial"> STATUS =
DEFAULT</FONT>
<BR><FONT SIZE=3D2 FACE=3D"Arial"> DATA =
SOILS_shape</FONT>
FACE=3D"Arial"> CLASS</FONT>
FACE=3D"Arial"> &nbs=
p; OUTLINECOLOR 128 128 128</FONT>
p; COLOR 225 225 185</FONT>
FACE=3D"Arial"> END #-- End =
class def.</FONT>
<BR><FONT SIZE=3D2 FACE=3D"Arial"> END #--End Layer def.</FONT>
</P>
<P><FONT SIZE=3D2 FACE=3D"Arial">END #-- End Map File</FONT>
</P>
</BODY>
</HTML>
------=_NextPart_000_0006_01C44E23.51E72060--
