[Mapserver-users] crash using srs parameter in getmap request
Kralidis,Tom [Burlington]
Tom.Kralidis at ec.gc.ca
Thu Jun 10 09:04:21 EDT 2004
Comments:
- What do you mean by MapServer crashing? Are you getting a 500 error?
Are you getting an OGC Service Exception Report XML document?
- What is the *native* projection of the data? This is what should be
declared in the PROJECTION block foreach layer
- try your "wms_srs" declaration with lowercase (i.e. "init=epsg:28992")
- trying a WMS GetMap request without the SRS keyword is an invalid
request, and should throw an exception
- WMS is not the problem. A WMS shall support all SRS projections it
advertises in Capabilities
..Tom
Tom Kralidis
Systems Scientist
Environment Canada
Tel: +01-905-336-4409
http://www.ec.gc.ca/
> -----Original Message-----
> From: mapserver-users-admin at lists.gis.umn.edu
> [mailto:mapserver-users-admin at lists.gis.umn.edu] On Behalf Of
> craig.gould at bt.com
> Sent: Thursday, June 10, 2004 7:33 AM
> To: john.pulles at geodan.nl; mapserver-users at lists.gis.umn.edu
> Subject: RE: [Mapserver-users] crash using srs parameter in
> getmap request
> John,
> I and a few others have found the same problem.
> The way round it is to create a web page that is called
> instead of the opengis mapserver. This page forwards the
> request to the mapserver but strips out the SRS paramater. If
> the map server is using the projection you want returned by
> default, then everything ends up OK. BTW this only happens
> with certain projection types. Regards, Craig.
> John Pulles
> Sent: 10 June 2004 10:28
> To: mapserver-users at lists.gis.umn.edu
> Subject: [Mapserver-users] crash using srs parameter in getmap request
> Hi List
> Using a map file with projection settings as shown below, I
> get a crash of mapserver when doing an opengis getmap request
> with &srs=epsg:28992. With an absent srs parameter or with
> &srs=epsg:4326 a correct map is returned. Does anyone have an
> idea what could be wrong?
> BTW: I am using MapServer version 4.2-beta2 on W2K, with the
> PROJ_LIB environment variable set to the directory containing
> the epsg file.
> Regards,
> John Pulles.
> MAP
> NAME "Demo"
> PROJECTION
> # RD
> "init=EPSG:28992"
> END
> EXTENT 10000 305000 280000 619000
> SHAPEPATH "c:\kaarten"
> UNITS meters
> WEB
> METADATA
> "wms_title" "Demo"
> "wms_srs" "EPSG:4326 EPSG:28992"
> END
> END
> LAYER
> NAME provincies
> DATA "provincies"
> STATUS ON
> METADATA
> "wms_title" "Provincies"
> END
> TYPE POLYGON
> CLASS
> COLOR 212 212 212
> OUTLINECOLOR 0 0 0
> END
> PROJECTION
> # RD
> "init=EPSG:28992"
> END
> END
> END
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/maps> erver-users
