[Mapserver-users] WMS flash problem
Sebastiaan Raaphorst
sebastiaan at locatienet.com
Fri Jun 11 06:18:31 EDT 2004
This is a multi-part message in MIME format.
------_=_NextPart_001_01C44F9D.71FCB2A4
Content-Type: text/plain;
charset="us-ascii"
Content-Transfer-Encoding: quoted-printable
Hi everyone,
=20
I have a problem using mapserver as a WMS server with flash output.
=20
- if I use the mapfile in combination with a template flash output works
fine
- if i make a WMS request for the same mapfile with other output formats
(e.g. image/gif) everything also works fine
=20
- the same WMS request with flash output however doesn't work, The flash
plugin loads but the browser keeps loading and no results appear
=20
>From the above it seems that the mapfile is ok, flash output is
supported and the correct mime type is send to the browser.
=20
Any ideas ?
=20
Regards
Sebastiaan
=20
=20
=20
=20
MapServer version 4.0.2 on windows XP using IIS.
OUTPUT=3DGIF OUTPUT=3DPNG OUTPUT=3DJPEG OUTPUT=3DWBMP OUTPUT=3DPDF
OUTPUT=3DSWF SUPPORTS=3DPROJ SUPPORTS=3DFREETYPE SUPPORTS=3DWMS_SERVER
SUPPORTS=3DWMS_CLI
ENT SUPPORTS=3DWFS_SERVER SUPPORTS=3DWFS_CLIENT INPUT=3DEPPL7 =
INPUT=3DPOSTGIS
INPUT=3DOGR
INPUT=3DGDAL INPUT=3DSHAPEFILE
Content-Type: text/html;
charset="us-ascii"
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META HTTP-EQUIV=3D"Content-Type" CONTENT=3D"text/html; =
charset=3DUS-ASCII">
<TITLE>Message</TITLE>
<META content=3D"MSHTML 6.00.2800.1400" name=3DGENERATOR></HEAD>
<BODY>
<DIV><SPAN class=3D197074609-11062004><FONT face=3DArial size=3D2>Hi=20
everyone,</FONT></SPAN></DIV>
<DIV><SPAN class=3D197074609-11062004><FONT face=3DArial=20
size=3D2></FONT></SPAN> </DIV>
<DIV><SPAN class=3D197074609-11062004><FONT face=3DArial size=3D2>I have =
a problem=20
using mapserver as a WMS server with flash =
output.</FONT></SPAN></DIV>
<DIV><SPAN class=3D197074609-11062004><FONT face=3DArial size=3D2>- if I =
use the=20
mapfile in combination with a template flash output works=20
fine</FONT></SPAN></DIV>
<DIV><SPAN class=3D197074609-11062004><FONT face=3DArial size=3D2>- if i =
make a WMS=20
request for the same mapfile with other output formats (e.g.=20
image/gif) everything also works fine</FONT></SPAN></DIV>
<DIV><SPAN class=3D197074609-11062004><FONT face=3DArial size=3D2>- the =
same WMS=20
request with flash output however doesn't work, The flash plugin =
loads but=20
the browser keeps loading and no results appear</FONT></SPAN></DIV>
<DIV><SPAN class=3D197074609-11062004><FONT face=3DArial size=3D2>From =
the above it=20
seems that the mapfile is ok, flash output is supported and the correct =
mime=20
type is send to the browser.</FONT></SPAN></DIV>
<DIV><SPAN class=3D197074609-11062004><FONT face=3DArial size=3D2>Any =
ideas=20
?</FONT></SPAN></DIV>
size=3D2>Regards</FONT></SPAN></DIV>
size=3D2>Sebastiaan</FONT></SPAN></DIV>
<DIV><SPAN class=3D197074609-11062004><FONT face=3DArial =
size=3D2>MapServer version=20
4.0.2 on windows XP using IIS.</FONT></SPAN></DIV>
size=3D2>OUTPUT=3DGIF=20
OUTPUT=3DPNG OUTPUT=3DJPEG OUTPUT=3DWBMP =
OUTPUT=3DPDF<BR> OUTPUT=3DSWF SUPPORTS=3DPROJ=20
SUPPORTS=3DFREETYPE SUPPORTS=3DWMS_SERVER SUPPORTS=3DWMS_CLI<BR>ENT=20
INPUT=3DPOSTGIS=20
INPUT=3DOGR<BR>INPUT=3DGDAL =
INPUT=3DSHAPEFILE</FONT></SPAN></DIV></BODY></HTML>
------_=_NextPart_001_01C44F9D.71FCB2A4--
