[Mapserver-users] oracle spatial mapfile
Fortin,Nicolas [SteFoy]
nicolas.fortin at ec.gc.ca
Fri Jun 11 08:45:34 EDT 2004
Is your version of mapserver compile with Oracle Spatial support??
Nicolas
-----Message d'origine-----
De : mapserver-users-admin at lists.gis.umn.edu [mailto:mapserver-users-admin at lists.gis.umn.edu] De la part de Sylvain Beorchia
Envoyé : Friday, June 11, 2004 5:53 AM
À : mapserver-users at lists.gis.umn.edu
Objet : [Mapserver-users] oracle spatial mapfile
Hi list,
I try to display some data from oracle spatial in my mapserver project. It doesn't work. Here is my mapfile layer:
LAYER
NAME spa
METADATA
"DESCRIPTION" "Spatial"
"LEGENDE" "1"
"TYPE_LAYER" "ORA"
END
STATUS ON
CONNECTIONTYPE oraclespatial
CONNECTION "spa/sig at spa"
DATA "GEOLOC from FP10010_LINES"
TYPE LINE
CLASS
OUTLINECOLOR 0 0 0
COLOR 0 128 128
END
END
The data in the database are from some Mapinfo TabFiles. SO i've got a table FP10010_LINES with the GEOLOC field, that's why i've tried to retreive data with "GEOLOC from FP10010_LINES".
So, when i launch my IE, i've got the following errors :
"Warning: MapServer Error in msOracleSpatialLayerOpen(): OracleSpatial is not supported in C:\ms4w\apps\gmap\htdocs\gmap.php3 on line 616"
"Fatal error: Call to a member function on a non-object in C:\ms4w\apps\gmap\htdocs\gmap.php3 on line 617"
My oracle version is 8i (8.1.7)
Any ideas ?
Thank u.
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
