[Mapserver-users] Mapserver doesn't create image, no crash
Zamil Murji Zamil.Murji at divestco.com
Fri Jun 11 11:49:46 EDT 2004
I used to get this same problem when when of my .qix files became obsolete.
Let's say I had a .shp file, ran shptree on it to create my index file.
Came along a week later and replaced the original .shp file with an
updated one, but I didn't bother to recreate the index file. In this case
you will not get an image but also no errors either. Hope this helps.
Zamil
-----Original Message-----
[mailto:mapserver-users-admin at lists.gis.umn.edu]On Behalf Of Berend
Veldkamp
Sent: Friday, June 11, 2004 9:21 AM
Cc: Mapserver Users
Subject: Re: [Mapserver-users] Mapserver doesn't create image, no crash
I seem to have found a workaround: I deleted all the index files (*.qix)
and so far everything works. Can anyone comment on this?
Berend
Möri Cédric wrote:
> Hi Berend
> sadly engouh I've got no hint for you. We are suffering of exactly the same
> problem:
> We are running about 15 projects/mapfiles on the same cgi, but the problem
> occurs only in one project which worked fine in 3.6.
> I reduced the number of layers in the project from about 25 to 10, but still
> the same. We tried all your ideas also with no success. We also tried to
> eliminate all LABELCACHE and POSTLABELCACHE in the mapfile.
> We are running MapServer 4.0.1 on RedHat 7.2.
> If anyone has an idea or the solution of the problem please let me/us know!
> Best regards
> Cédric
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
