[Mapserver-users] crash using srs parameter in getmap request
bartvde at xs4all.nl
Fri Jun 11 16:02:09 EDT 2004
Hi John,
4.2 release binaries are available at Maptools.org. I would suggest to try
them out to see if the problem really disappeared.
http://www.maptools.org/dl/mapserver-4.2.0-win32-php4.3.4.zip
Best regards,
Bart
> Ed McNierney wrote:
>>Folks -
>>What version of MapServer are you running when you get this crash? My
>>memory is being fuzzy right now, but there was a bug quite a while ago
>>that had something to do with a buffer/pointer problem with SRS
>>parameters (I think). I ran into it and Daniel fixed it - but it was
>>rather a long time ago. If you're using an old version of MapServer,
>>try something newer.
> Hi again,
> The crash 'succeeded' with MapServer version 4.2-beta2 on W2K (from
> http://160.94.77.165/ms42b2_gif_pg.zip). As far as I know, mapserver
> version 4.2 is only available as a beta, so after suggestions to upgrade
> to version 4.2, it seemed worth to try to build mapserver 4.2 on Linux.
> With this version the crash does NOT occur and the url returns an image
> with or without srs parameters for both desired projections.
> Question that remains is if the problem in beta2 occurred because of
> the beta status or because of the windows version?
> John.
>> - Ed
>>Ed McNierney
>>President and Chief Mapmaker
>>TopoZone.com
>>-----Original Message-----
>>From: mapserver-users-admin at lists.gis.umn.edu
>>[mailto:mapserver-users-admin at lists.gis.umn.edu] On Behalf Of
>>craig.gould at bt.com
>>Sent: Thursday, June 10, 2004 9:17 AM
>>To: Tom.Kralidis at ec.gc.ca; john.pulles at geodan.nl;
>>mapserver-users at lists.gis.umn.edu
>>Subject: RE: [Mapserver-users] crash using srs parameter in getmap
>>request
>>Tom,
>>If John's crash is anything like the crash I experienced then it is the
>>actual mapserv process on the machine that crashes with a null pointer
>>exception somewhere.
>>This crash only happens with certain types of projections. I was using
>>British National Grid (BNG). The native projection of the WMS server was
>>BNG, and the native projection of the WMS client was BNG. However if I
>>include the SRS parameter then the map server process on the WMS server
>>crashed (however not if you used a browser and did a standard request).
>>If I took out the SRS parameter via a redirecting page the process did
>>not crash.
>>Upper and lower case made no difference for me. The application still
>>crashed.
>>BTW, when I found this problem I posted it on this list, but got no
>>answer back. Since then at least two other people have posted similar
>>problems. Each time I've let them know how I got round the problem.
>>Unfortunately I can't get seem to get map server to compile on my win
>>machine so I can't look into where this may be happening.
>>Craig.
>>From: Kralidis,Tom [Burlington] [mailto:Tom.Kralidis at ec.gc.ca]
>>Sent: 10 June 2004 14:04
>>To: Gould,CR,Craig,XGH6A C; john.pulles at geodan.nl;
>>request
>>Comments:
>>- What do you mean by MapServer crashing? Are you getting a 500 error?
>>Are you getting an OGC Service Exception Report XML document?
>>- What is the *native* projection of the data? This is what should be
>>declared in the PROJECTION block foreach layer
>>- try your "wms_srs" declaration with lowercase (i.e. "init=epsg:28992")
>>- trying a WMS GetMap request without the SRS keyword is an invalid
>>request, and should throw an exception
>>- WMS is not the problem. A WMS shall support all SRS projections it
>>advertises in Capabilities
>>..Tom
>>Tom Kralidis
>>Systems Scientist
>>Environment Canada
>>Tel: +01-905-336-4409
>>http://www.ec.gc.ca/
>>>Sent: Thursday, June 10, 2004 7:33 AM
>>>To: john.pulles at geodan.nl; mapserver-users at lists.gis.umn.edu
>>>getmap request
>>>John,
>>>I and a few others have found the same problem.
>>>The way round it is to create a web page that is called
>>>instead of the opengis mapserver. This page forwards the
>>>request to the mapserver but strips out the SRS paramater. If
>>>the map server is using the projection you want returned by
>>>default, then everything ends up OK. BTW this only happens
>>>with certain projection types. Regards, Craig.
>>>John Pulles
>>>Sent: 10 June 2004 10:28
>>>To: mapserver-users at lists.gis.umn.edu
>>>Subject: [Mapserver-users] crash using srs parameter in getmap request
>>>Hi List
>>>Using a map file with projection settings as shown below, I
>>>get a crash of mapserver when doing an opengis getmap request
>>>with &srs=epsg:28992. With an absent srs parameter or with
>>>&srs=epsg:4326 a correct map is returned. Does anyone have an
>>>idea what could be wrong?
>>>BTW: I am using MapServer version 4.2-beta2 on W2K, with the
>>>PROJ_LIB environment variable set to the directory containing
>>>the epsg file.
>>>Regards,
>>>John Pulles.
>>>MAP
>>> NAME "Demo"
>>> PROJECTION
>>> # RD
>>> "init=EPSG:28992"
>>> END
>>> EXTENT 10000 305000 280000 619000
>>> SHAPEPATH "c:\kaarten"
>>> UNITS meters
>>> WEB
>>> METADATA
>>> "wms_title" "Demo"
>>> "wms_srs" "EPSG:4326 EPSG:28992"
>>> END
>>> END
>>> LAYER
>>> NAME provincies
>>> DATA "provincies"
>>> STATUS ON
>>> METADATA
>>> "wms_title" "Provincies"
>>> END
>>> TYPE POLYGON
>>> CLASS
>>> COLOR 212 212 212
>>> OUTLINECOLOR 0
>>> END
>>> PROJECTION
>>> # RD
>>> "init=EPSG:28992"
>>> END
>>> END
>>>END
>>>_______________________________________________
>>>Mapserver-users mailing list Mapserver-users at lists.gis.umn.edu
>>>http://lists.gis.umn.edu/mailman/listinfo/maps> erver-users
>>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
> Geodan IT b.v.
> Buitenhaven 27-A
> 5211 TP 's-Hertogenbosch (NL)
> Tel: +31 (0)73 - 692 5151
> Fax: +31 (0)73 - 692 5150
> Mobiel: +(0)6 - 1234 5678
> Postadres / mailing address
> President Kennedylaan 1
> 1079 MB Amsterdam (NL)
> E-mail: john.pulles at geodan.nl
> Website: http://www.geodan.nl
> Disclaimer: http://www.geodan.nl/disclaimer
