[Mapserver-users] Using OS MasterMap with MapServer
Andrew Haigh andrew at andrewhaigh.net
Sat Jun 12 11:39:11 EDT 2004
--Apple-Mail-1--774114367
Content-Transfer-Encoding: quoted-printable
Content-Type: text/plain;
	charset=GB2312;
	format=flowed
According to the GDAL site (http://gdal.maptools.org/ogr/drv_gml.html),=20=
OGR supports GML Version 2.0 and MasterMap is supplied in GML 2.1.2=20
(see www.opengis.org for details of the spec).
I'd start be attempting to read the MasterMap GML using the OGR/GDAL=20
GML reader and see if that works.
If it does work, then you might want to try and convert the GML to a=20
Shapefile / postgis using ogr2ogr, to see if that improves performance.
If that doesn't work, then you'll have to code something - PHP 'may' be=20=
the ideal tool, as it support gzip and xml.
You'll have to ask the PHP guys if you can stream a GZIP file, into PHP=20=
(as you can in Java) or you'll need loads of RAM.
If you wanted to load GML into a database (PostgreSQL with PostGIS)=20
then you could try these steps:
1. Decompresses the GML (as it comes with GZIP compression) - although,=20=
using a stream would be much better (unless you have a very small=20
dataset)
2. Reads the GML (XML) and convert it to OGC Simple Features - you'll=20
need to read the very long MasterMap Spec and split out the Polygon,=20
Line, point and annotation features
3. Load the OGC Simple Feature into a Spatial Database - PostgreSQL=20
(with PostGIS), MySQL?
4. Index the TOID (Topographic Identifier)  and the geometry - this=20
will be used for updates
5. Log rejected features
6. You'd need some code to apply the update files from the OS - If your=20=
client has the  MasterMap supplied as Change Only Update (COU).
If it could work with your end product (and the OS License), the OS=20
provides a GML to SVG (Scaleable Vector Graphics) Stylesheet on it's=20
website.
I think that most commercial organizations and even the OS would=20
recommend loading the data into a DBMS - be warned unless you have a=20
very small area of data, the database will be huge.
Also, look at FME - it can convert most things=20
(http://www.safe.com/products/fme/formats/index.php).
Hope this helps.
Andrew
On 12 Jun 2004, at 12:06, guoloi dou wrote:
> Thank you for your reply. I'm afraid that MasterMap is in GML. Do you=20=
> mean that OGR/GDAL may read GML MasterMap? If not, what do you=20
> recommend that GML should be converted to?
> =20
> Regards,
> Zhengda Lu
> =20
> Andrew Haigh <andrew at andrewhaigh.net> wrote:
> It all depends what format your MasterMap is in? GML? Shapefile?
>  MapInfo Tab?
> Getting MasterMap. to work from a shapefile is easy, however, if your
>  data is GML then I think you'll need convert it.
> You might be able to read it in via OGR/GDAL but I've never tried it
> (www.remotesensing.org/gdal/), if your using the none topographically
>  structured version.
> If you look on the OS website
>  (http://www.ordnancesurvey.co.uk/oswebsite/products/osmastermap/
>  systems/index.html) this will tell you what software claims to be
> compatabile.
> Not sure if this is helpful or not.
> Regards,
> Andrew
> On 10 Jun 2004, at 13:52, guoloi dou wrote:
> > I am new to GIS and am trying to implement a web-based navigation
>  > system to display Ordnance Survey MasterMap data. Below=A0are the
>  > technologies availabe:
> > 1.PHP;
> > 2.MySQL;
> > 3.OS MasterMap
> > 4.MapServer
> > 5.Apache on Windows XP
> > ?lt;br>> Could someone tell me how MasterMap be used by MapServer so=20=
> that I can
>  > extract location information from MapServer and MySQL?
> > ?lt;br>> Your help would be appreciated
> > ?lt;br>> Best regards,
> > Zhengda Lu
> Do You Yahoo!?
> =CF=D3=D3=CA=CF=E4=CC=AB=D0=A1=A3=BF=D1=C5=BB=A2=B5=E7=D3=CA=D7=D4=D6=FA=
=C0=A9=C8=DD=A3=A1=
Content-Type: text/enriched;
	charset=GB2312
(http://gdal.maptools.org/ogr/drv_gml.html), OGR supports GML Version
2.0 and MasterMap is supplied in GML 2.1.2 (see www.opengis.org for
be the ideal tool, as it support gzip and xml.=20
PHP (as you can in Java) or you'll need loads of RAM.
although, using a stream would be much better (unless you have a very
small dataset)
your client has the  MasterMap supplied as Change Only Update (COU).
website.
Hope this helps.
Andrew
<excerpt>Thank you for your reply. I'm afraid that MasterMap is in
GML. Do you mean that OGR/GDAL may read GML MasterMap? If not, what do
you recommend that GML should be converted to?
=20
Regards,
Zhengda Lu
=20
<bold><italic>Andrew Haigh <<andrew at andrewhaigh.net></italic></bold>
 MapInfo Tab?
You might be able to read it in via OGR/GDAL but I've never tried it=20
 structured version.
 systems/index.html) this will tell you what software claims to be=20
compatabile.
Regards,
Andrew
Below<fontfamily><param>Hiragino Kaku Gothic =
Pro</param>=A0a</fontfamily>re
the
> 1.PHP;
> 2.MySQL;
> 3.OS MasterMap
> 4.MapServer
that I can
> Zhengda Lu
<bold>Do You Yahoo!?</bold>
Pro</param><color><param>0000,0000,EEEE</param>=CF=D3</color></fontfamily>=
<fontfamily><param>STHeiti</param><color><param>0000,0000,EEEE</param>=D3=CA=
=CF=E4=CC=AB=D0=A1=A3=BF=D1=C5=BB=A2=B5=E7=D3=CA=D7=D4=D6=FA=C0=A9=C8=DD=A3=
=A1</color></fontfamily></excerpt>=
--Apple-Mail-1--774114367--
