[Mapserver-users] WMSClient and libcurl
Jin-Yong Choi
jychoi at ecn.purdue.edu
Mon Jun 14 10:45:40 EDT 2004
--------------010704040004080003000702
Content-Type: text/plain; charset=us-ascii; format=flowed
Content-Transfer-Encoding: 7bit
I'd like to compile MapServer for wmsclient.
While trying to run configure, I met the error follows.
I tried to run configure with curllib 7.12.0, as it was same.
Could you tell me how I can solve the problem?
Thanks.
./configure: ../curl-7.10.8/curl-config: bad interpreter: Permission denied
found libcurl version
configure: error: libcurl version 7.10.1 or more recent is required.
Jin-Yong Choi
Jin-Yong Choi, Ph. D. :-)
Environmental DSS Scientist
Agr. & Bio. Engineering, Purdue University
Tel. 765-494-1196
Fax. 765-496-1115
http://pasture.ecn.purdue.edu/~watergen
<http://pasture.ecn.purdue.edu/%7Ewatergen>
Content-Type: text/html; charset=us-ascii
<!DOCTYPE html PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
<html>
<head>
<title></title>
</head>
<body>
I'd like to compile MapServer for wmsclient.<br>
While trying to run configure, I met the error follows.<br>
I tried to run configure with curllib 7.12.0, as it was same.<br>
Could you tell me how I can solve the problem?<br>
Thanks.<br>
--------------------------------------------------------<br>
./configure: ../curl-7.10.8/curl-config: bad interpreter: Permission denied<br>
found libcurl version<br>
configure: error: libcurl version 7.10.1 or more recent is required.<br>
<br>
Jin-Yong Choi<br>
<div class="moz-signature"><br>
<title></title>
<title></title>
<title></title>
<title></title>
<title></title>
<title></title>
<address><font color="#996633">===========================<br>
Jin-Yong Choi, Ph. D.<span class="moz-smiley-s1"><span> :-) </span></span></font></address>
<address><font color="#996633">Environmental DSS Scientist</font></address>
<address><font color="#996633">Agr. & Bio. Engineering, Purdue University</font></address>
<address><font color="#996633">Tel. 765-494-1196</font></address>
<address><font color="#996633">Fax. 765-496-1115<br>
<a href="http://pasture.ecn.purdue.edu/%7Ewatergen"><u>http://pasture.ecn.purdue.edu/~watergen</u></a></font></address>
</div>
</body>
</html>
--------------010704040004080003000702--
