[Mapserver-users] Drawing Lines - Perl
Sidnei de Souza
sidnei at cria.org.br
Mon Jun 14 11:28:08 EDT 2004
Dear all,
I'm having a problem drawing lines on-the-fly with Perl mapscript and
haven't found anything in the list archive that can help me.
I'm attaching a perl script that I think should work, but a blank image
is produced.
I'm trying this in a RedHat Linux, with mapserver 4.2.0
If I change the layer and shape types to POLYGON instead of LINE, a
correct polygon is produced.
Any help will be very welcome!
Thanks
sidnei
#!/usr/local/bin/perl
use mapscript;
$map = new mapscript::mapObj('') || die;
$map->setProjection('proj=longlat');
$map->{width} = 300;
$map->{height} = 250;
$map->{extent}->{minx} = -53.11;
$map->{extent}->{maxx} = -44.16;
$map->{extent}->{miny} = -25.30;
$map->{extent}->{maxy} = -19.78;
my $img = $map->prepareImage();
my $point = new mapscript::pointObj();
my $line = new mapscript::lineObj();
my $shape = new mapscript::shapeObj($mapscript::MS_SHAPE_LINE);
my $layer = new mapscript::layerObj($map);
$layer->{'type'} = $mapscript::MS_LAYER_LINE;
$layer->{'name'} = 'myline';
$layer->{'status'} = 1;
$layer->setProjection('proj=longlat');
my $class = new mapscript::classObj($layer);
$class->{numstyles} = 1;
$class->{name} = 'myclass';
$class->{styles}->{symbol} = 0;
$class->{styles}->{color}->{red} = -1;
$class->{styles}->{color}->{green} = -1;
$class->{styles}->{color}->{blue} = -1;
$class->{styles}->{outlinecolor}->{red} = 255;
$class->{styles}->{outlinecolor}->{green} = 0;
$class->{styles}->{outlinecolor}->{blue} = 0;
$class->{styles}->{'minsize'} = 2;
$class->{styles}->{'maxsize'} = 20;
$class->{styles}->{'size'} = 5;
$point->{x} = -47.0608;
$point->{y} = -22.9056;
$line->add($point);
$point->{x} = -45.65;
$point->{y} = -24.55;
$line->add($point);
$point->{x} = -46.65;
$point->{y} = -25.55;
$line->add($point);
$line->add($point);
$shape->add($line);
$shape->draw($map,$layer,$img);
$layer->draw($map,$img);
$img->save('myimage.png');
Sidnei de Souza
Diretor de Informática, CRIA
"Feliz aquele que transfere o que sabe e aprende o que ensina." [Cora Coralina]
