[Mapserver-users] Pdf output shows junk on the browser?
Antti.Roppola at brs.gov.au
Mon Jun 14 19:53:37 EDT 2004
What sort of junk?
If it looks like this, you are getting a PDF file, but it is not
being recognised by the end-user as one:
%PDF-1.3
%äãÏÒ
5 0 obj
<</Length 6 0 R
/Filter/FlateDecode
stream
x~\~D½I²$I®$¸~OS¼^K´~SÌö~Iê^Fu^BëEmÂ6ÿþ~K^F3CÌó©À²èS~÷~@«ªÉ~H~Q^Aä~_
I have noticed that the PDF output file includes a MIME header
in the first couple of lines. Depending on how you are generating
and sending the file, this might be a problem. If so, try open the
PDF file and delete everything before "%PDF-" before sending it to
the browser. Also try opening the file from your PDF reader. Aka,
the first thing to do is confirm that a valid PDF file is being created.
Cheers,
Antti
-----Original Message-----
Sent: Friday, 11 June 2004 5:38 PM
To: mapserver-users at lists.gis.umn.edu; mhln25 at yahoo.com
Subject: Re: [Mapserver-users] Pdf output shows junk on the browser?
Hello
If your PDF configuration in the map file is correct and you do have installed Adobe Acrobat and/or Reader, the problem might be caused by some browser related issues.
Especially recent IE versions have trouble displaying server side (created) PDF's properly.
Take a look at the following links for more info:
http://www.adobe.com/support/techdocs/29776.htm
http://forum.planetpdf.com/wb/default.asp?action=9&fid=6&read=41191
http://www.bnl.gov/itd/webapps/pdf_help.asp
Groeten,
Emil Zegers
De Straat Milieu-adviseurs
Divisie Informatisering
026 7513902
06 22965585
http://www.destraat.nl
>>> Mahalakshmi Narayanan <mhln25 at yahoo.com> 06/11/04 08:09 AM >>>
Hi!
I tried to output my map as a pdf but I get junk
thrown to me when I include the following outputformat
tag..
OUTPUTFORMAT
NAME pdf
MIMETYPE "application/x-pdf"
DRIVER pdf
# FORMATOPTION "OUTPUT_TYPE=RASTER"
EXTENSION "pdf"
END
I am running windows xp with
MapServer version 4.0.2 OUTPUT=GIF OUTPUT=PNG
OUTPUT=JPEG OUTPUT=WBMP OUTPUT=PDF
OUTPUT=SWF SUPPORTS=PROJ SUPPORTS=FREETYPE
SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLI
ENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT
INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR
INPUT=GDAL INPUT=SHAPEFILE
do i need anything else to be installed on my box to
get pdf output?
can somebody help me, pls.
With regards,
__________________________________
Do you Yahoo!?
Friends. Fun. Try the all-new Yahoo! Messenger.
http://messenger.yahoo.com/
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
__________
VChecked
______________________________________________________
This message has been checked for all known viruses
