[Mapserver-users] cgi-apt-get debian
Lars Möller
moeller at basis5.de
Tue Jun 15 07:28:27 EDT 2004
thanks
the error:
Premature end of script headers: /www/1/cgi-bin/mapserv
not very usefull I think : (
lars
James Cradock schrieb:
> Lars,
> What's the output from Apache's error log? It should be in
> /var/log/apache/error.log. Or try this from a terminal (command line)
> window:
> tail -f /var/logl/apache/error.log | grep mapserv
> Jim
>>hello list,
>>has someone installed mapserver via apt-get on debian?
>>it installs the mapserv under /usr/lib/cgi-bin/mapserv
>>calling the file directly gives:
>>This script can only be used to decode form results and
>>should be initiated as a CGI process via a httpd server.
>>that should be ok.
>>calling mapser -V gives:
>>MapServer version 4.0.1 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP SUPPORTS=PROJ
>>SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
>>SUPPORTS=WFS_CLIENT INPUT=TIFF INPUT=EPPL7 INPUT=JPEG INPUT=OGR
>>INPUT=GDAL INPUT=SHAPEFILE
>>that is also ok.
>>if I copie the file (mapserv) in the cgi -directory of the apache and
>>calling it from the web i get internal server error.
>>what is wrong?
>>thanks for ideas and help
>>lars
>>_______________________________________________
>>Mapserver-users mailing list
>>Mapserver-users at lists.gis.umn.edu
>>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
> James Cradock, jcradock at me3.com
> me3 Technology Consultants, LLC
> 24 Preble Street
> Portland, Maine, USA 04101
> http://www.me3.com/
dipl.-ing. lars möller
basis5 - webtechnologie
möller und zipp ingenieure
und partner
malsburgstrasse 14
34119 kassel
tel 0561.7660348
fax 0561.7660358
email moeller at basis5.de
www.basis5.de
