[Mapserver-users] mapserver and context-based
Kralidis,Tom [Burlington]
Tom.Kralidis at ec.gc.ca
Wed Jun 16 08:42:42 EDT 2004
You can use MapServer for Web Map Context Documents with PHP MapScript, which has two methods within the map object:
loadMapContext();
saveMapContext();
Check out the PHP docs for more info.
There is also a 'hidden' feature you can specify in your mapfile WEB METADATA object:
"wms_getcontext_enabled" "1"
..which, if specified, allows for MapServer CGI to respond to:
http://host/mapserv?map=map.map&request=GetContext
..keep in mind this is turned OFF by default, as the mapfile WMS connections may have information you may or may not want to expose.
Hope this helps.
..Tom
Tom Kralidis
Systems Scientist
Environment Canada
Tel: +01-905-336-4409
http://www.ec.gc.ca/
-----Original Message-----
From: mapserver-users-admin at lists.gis.umn.edu [mailto:mapserver-users-admin at lists.gis.umn.edu] On Behalf Of cristinanoversa at clix.pt
Sent: Wednesday, June 16, 2004 6:36 AM
To: mapserver-users at lists.gis.umn.edu
Subject: [Mapserver-users] mapserver and context-based
I would like that someone could share with me some knowledge about mapserver and its use in context-based applications. Can anyone point me some existing applications?
Thanks
Cristina
Clix Rapidix - Aumente até 6X a velocidade da sua Internet
Adira em http://acesso.clix.pt e comece logo a navegar
_______________________________________________ Mapserver-users mailing list Mapserver-users at lists.gis.umn.edu http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
