[Mapserver-users] Help please with Query problem
1wilkerson at charter.net
Wed Jun 16 12:20:01 EDT 2004
Steve--
Thanks for the suggestion. I had not approached it from that perspective. I'll try it.
With much appreciation!
Peter
> From: Stephen Woodbridge <woodbri at swoodbridge.com>
> Date: 2004/06/16 Wed PM 12:12:49 EDT
> To: 1wilkerson at charter.net
> CC: Mapserver-users at lists.gis.umn.edu
> Subject: Re: [Mapserver-users] Help please with Query problem
> Peter,
> I think you can do this by creating two layers using the same data file
> and setting the class up to select "RES" and style it one way and then
> to select "COM" in the other layer and style it a different way.
> I do this with street data so I can label the streets with text names
> and also place route badges on the same streets. You have to do it with
> two layers because want to put two different stylings on the same
> object. Have two layers means you take two passes over the data once in
> each layer.
> -Steve W.
> 1wilkerson at charter.net wrote:
> > Hi!
> > I am still very much new to Mapserver and need help. Would somebody check my earlier message requesting help? I really could use some input. The message URL is:
> > http://lists.gis.umn.edu/pipermail/mapserver-users/2004-June/013954.html
