[Mapserver-users] MapInfo example (was: thanks for your answers guys)
Tyler Mitchell tjmitchell at riverside.bc.ca
Wed Jun 16 12:22:50 EDT 2004
> if i understand what you're saying :
> using MAPINFO in mapserver i am obliged to write manually the .map file
> and refer to the .tab .
> MapInfo sftware doesn't provide a .map file ready to use in mapserver.
> is that correct ?
> If someone has an full example of MapInfo mapfile i am interested in !!
Here's an example for you Eric, which Jeff McKenna pulled together for a
recent workshop, hope it helps you out.
It shows the syntax of using the ogrinfo utility (from GDAL/OGR package)
to give you more info about the file and also shows a mapfile example.
MapInfo Files
Also known as TAB or MID/MIF files.
File listing
The following files are also associated with .TAB files: .DAT, .ID, .MAP.
An example is:
border.DAT border.ID border.MAP border.TAB
The term MID/MIF refers to files with .MID and .MIF extension.
Data Access / Connection Method
1.      TAB and MID/MIF access is available in MapServer through OGR.
2.      The CONNECTIONTYPE OGR parameter must be used.
3.      The path to the (*.tab or *.mif) file is required, and file
extension is needed.
4.      The path may be relative to the SHAPEPATH
5.      DGN files already contain "styling" information. This styling
information can be used (optionally) by specifying the STYLEITEM "AUTO"
parameter in the LAYER object of the mapfile.
6.      If you use STYLEITEM "AUTO" you must have an empty class in the
layer
OGRINFO Examples
ogrinfo on a single TAB file
$ ogrinfo elev5_poly.TAB
Had to open data source read-only.
INFO: Open of `elev5_poly.TAB'
using driver `MapInfo File' successful.
1: elev5_poly (Polygon)
Using ogrinfo to examine the structure of the file/layer
$ ogrinfo elev5_poly.TAB elev5_poly
Layer name: elev5_poly
Geometry: Polygon
Feature Count: 2236
Extent: (-141.000000, 60.000000) - (-124.403310, 69.300251)
Layer SRS WKT:
GEOGCS["unnamed",
    DATUM["MIF 0",
        SPHEROID["WGS 84 (MAPINFO Datum 0)",6378137.01,298.257223563],
        TOWGS84[0,0,0,0,0,0,0]],
    PRIMEM["Greenwich",0],
    UNIT["degree",0.0174532925199433]]
AREA: Real (0.0)
PERIMETER: Real (0.0)
ELEV5_: Integer (0.0)
ELEV5_ID: Integer (0.0)
TYPE: Real (4.0)
ELEV5: Real (4.0)
Mapfile Syntax
LAYER
  NAME Elevation_Poly_5
  TYPE POLYGON
  STATUS DEFAULT
  CONNECTIONTYPE OGR
  CONNECTION "./hypso/elev5_poly.TAB"
  STYLEITEM "AUTO"
  CLASS
    NAME "Elevation Poly 5"
  END
  PROJECTION
    "proj=latlong" "ellps=WGS84" # Geographic
  END
END # Layer
