[Mapserver-users] Re: Help please with Query problem
1wilkerson at charter.net
Wed Jun 16 13:30:01 EDT 2004
I am still missing something obvious.
I tried implementing the solution Steve Woodbridge suggested but I encountered a problem.
If I create two different layers based on the same SHP file, how can it make sure the results don't overlap with one another? I would need to filter both SHP files based on the contents of two fields -- DATA_CODE and OCCUPATION
So...
Layer1 would be filtered on
DATA_CODE = RES and OCCUPATION = plumbers
Layer2 would be filtered on
DATA_CODE = COM and OCCUPATION = plumbers
How do I express that within PHP/Mapscript?
The full code I am using is at:
http://lists.gis.umn.edu/pipermail/mapserver-users/2004-June/013954.html
All help greatly appreciated!!
Peter
> From: Stephen Woodbridge <woodbri at swoodbridge.com>
> Date: 2004/06/16 Wed PM 12:12:49 EDT
> To: 1wilkerson at charter.net
> CC: Mapserver-users at lists.gis.umn.edu
> Subject: Re: [Mapserver-users] Help please with Query problem
> Peter,
> I think you can do this by creating two layers using the same data file
> and setting the class up to select "RES" and style it one way and then
> to select "COM" in the other layer and style it a different way.
> I do this with street data so I can label the streets with text names
> and also place route badges on the same streets. You have to do it with
> two layers because want to put two different stylings on the same
> object. Have two layers means you take two passes over the data once in
> each layer.
> -Steve W.
> 1wilkerson at charter.net wrote:
> > Hi!
> > I am still very much new to Mapserver and need help. Would somebody check my earlier message requesting help? I really could use some input. The message URL is:
> Mapserver-users mailing list
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
